Bracing a fiberglass body...?
Discussion in 'The Hokey Ass Message Board' started by Flynn's_57, Jun 5, 2004.
  1. Flynn's_57
    Flynn's_57
    from Nor*Cal
    So I picked up a t-bucket body for $150,
    But it needs the bracing/re-inforcement stuff-
    Somebody told me to use wood,
    But it seems like there will be too many curves for that.
    Uhhh....
    so anybody want to school me?
  2. oldchevyseller
    oldchevyseller
    from mankato mn
    i used 3/16th 3/4 angle and cut little reliefs to make the bends. and then welded em shut ,mada a skeleton inside turned out fabulous , but i do not have any pics as my puter ate all of em,
  3. marq
    marq
    a lot of the guys over here in the uk use tube,go to the local hire shop and get a tube bender for a few days,5/8 tube is the norm here.It takes a bit of practice to get it right but when it's done it will look real good and profesional,not only that it can be bent in real tight unlike angle.............Marq
  4. old beet
    old beet
    Around the upper back, I've used a garden hose full of epoxy then gl***ed into place, but that was in 1962........OLDBEET (its still there)
  5. InPrimer
    InPrimer
    check out boat places for different types of epoxies and/or gl*** fillers, use gl*** matting to adhere the tubing to the body(if you are going to use tubing) a lot of gl*** cars are reenforced with oak which is supposed to expand&contract the same as fibergl***. as far as bracing, get a ****load of cardboard, a good razor knife and trim away, duplicate to wood and you're home
  6. zibo
    zibo
    from dago ca
    cardboard
  7. UKAde
    UKAde
    from Oxford UK
    i used square 1 inch box to brace my body
    it's easy to join together as it doesn't require the tubes to be filed to fit like round tube it sits flat against the body giving more support to the gl***fibre
    at can be easly bent by making pie cuts and welding up on small tight bends or around a former like an old wheel rim for bigger bends
    take a look at my pics to see how i did it
    UKAde
  8. CharlieLed
    CharlieLed
    First a question...how much to you know about fibergl***?
    ***uming that you know how to mix the resin and apply the mat the following procedure will give you the strongest bond and the most support, pound for pound...
    Get some foam like they use for building surf boards, make sure that it's not polyester foam because the resin is also polyester and will melt that type of foam (ever put lacquer thinner in a foam coffee cup... [​IMG] )
    Shape the foam to fit the inside of the body in the areas that you would like to support. 1x3 inch shaped supports work well.
    Once you have your bracing shaped cover the inside of the body (just where the supports are being placed) with blue masking tape, the kind that is made to be removed easily. Put the foam supports in place and layup your fibergl*** mat and resin over the supports leaving about a 1 inch flange on each side of the support. This flange will give you a better bond for the final installation "bonding" step.
    Once the supports have been gl***ed and cured, remove them from the body and remove the tape. Buy some structural adhesive, this will be a 2-part epoxy made for bonding fiber reinforced plastic (FRP). This adhesive can be bought at most auto body supply houses or online.
    Remove the blue tape, clean the mating surfaces, and apply the adhesive and structural supports.
    This technique will give you a professional appearance, the strongest body, and the bond will be stronger than any bond you could achieve by laying new resin over previously cured fibergl*** (a mechanical bond in fibergl*** is a problem waiting to happen, avoid whenever possible!).
    poprodder and madmike8 like this.
  9. Deuce Rails
    Deuce Rails
    Is this for temporary reinforcement, like to keep the body square while you're aligning things?
    Or is it for permanent reinforcement, which is why you mention the many curves?
  10. Jimv
    Jimv
    Its very simple & cheap to do,i did it on mine & it held up great.
    Get some furring strips(2"x3/4") get some bondo with the fibers in it,some of those big orange roach clips from Odd lot.Then try & get a total performance ***embly manual.
    They give you all the lengths to cut the furring strips, then you just get the bondo( mix up only what you'll use quickly) Then put he bondo on the wood like your putting peanut ****er on bread,Then use the roach clips to hold it in place till it sets up.Really hold great & tightens the body right up.It also gives you something to tack the upolstory to.
    If you can't get a otal manual i'll seeif i hae mine & i'll take a picture of te page with the lay out on it.
    Trust me its a great cheap way to do it & it doesthe job.
    JimV
    Hot Rod Nut likes this.
  11. wedjim
    wedjim
    from Kissimmee
    Need to bookmark this page for ideas. Sorry for popping up an oldie.
  12. donzzilla
    donzzilla
    I use to make molds for them fake convertible tops. The fastest and easiest thing I found was conduit tubing. It's strong, bends easy, available in different diameters and the tools to bend it are inexpensive too. Bend it up, clamp it on and gl*** it up.
    I had guys that worked next to me use wood and I could make 4 molds to their 1. Mine were just as strong and didn't take up as much room either.
    Can't say that it helped, but some times I would drill little holes in the tubing for extra grip.
    Hope this helps, Zilla!
  13. prpmmp
    prpmmp
  14. a bloke
    a bloke
    I've heard of guys using rope - mix up some fg resin and stick the rope where you want to brace. You might have to clamp it. When the resin has set, cover the rope with FG cloth and resin as usual. The box section of the cloth over the rope gives good torsional strength.
  15. A Boner
    A Boner
    Use resin and fibergl*** cloth to reinforce your body. I used cardboard and masking tape to form a boarder channel 3/4" down from the top lip of my 27 T body. Then you can lay up the gl*** and resin in that channel. You have to lay the body upside down so with gravity, the resin doesn't run out, until it sets up. keep on going around the body adding more layers as it sets up. I didn't put any doors in my body, so with the 3/4" reinforced lip, it is so stable, that I didn't add any other body reinforcing.
  16. pasadenahotrod
    pasadenahotrod
    from Texas
    The reinforcement in my friends 23 Track T, built in 1969, is a piece of 1/2" rebar bent to fit under the top rail, then embedded in a bed of bondo and covered completely. The rebar was derusted and painted before installation, it runs the length of the cab rail and drops down slightly about 3" from the dash.
    He also carved a bar of oak to fit up in the cowl top at the dash. It too is bedded in bondo but not covered up. Several br*** wood screws through the face of the dash rail hold it in place. The steel steering column drop bolts through this reinforcement rail.
    The inside of the firewall is covered with a sheet of 3/4" plywood.
    The 3/4" plywood floor is bonded to the sidewalls of the body with fibregl*** kitty hair compound and a few br*** wood screws.
    Try to remember to add a few drain holes in the back edge of the floor to allow the rain to get out before bad stuff happens. If your car will have a rake this not so necessary but be sure IF your seat riser board runs wall to wall to have a drain hole or hole behind it so water can escape.
  17. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Let me throw an old boat hull trick into the mix. Get some 3/4" PVC pipe, cut it in half, use a torch to just soften it enough to bend to your contours, then gl*** in place. The reality is the gl*** is where the strength really is, but the pipe provides the form.
  18. mad mechanic
    mad mechanic
    some very good tips on here...subscribed
  19. Don's Hot Rods
    Don's Hot Rods
    from florida
    I realize this is a very old thread, but since it seems to be alive again, here is how I do a fibergl*** body:
    I do whatever it takes to hold the wood in place until the resin sets up.
  20. Hemi325
    Hemi325
    from Boerne, TX
    I've tried a lot of different things. Wood is fine, but if moisture gets in there it will dry rot. Foam is light and very shapeable. For ribs to keep fender edges from flexing or for floorboards, I got fibergl*** sheet from McMaster-Carr and gl***ed it in. They offer it in many sizes and thicknesses.
  21. Don's Hot Rods
    Don's Hot Rods
    from florida
    The secret to using wood is to seal the edges with resin and encapsulate every bit of it with fibergl***, that way moisture can't get in. The wooding in my 27 is over 25 years old and is as solid today as the day I did it, and that car has been in the rain lots of times over those 25 years. I used to even park it at work all day and it rains almost every day here in Florida.
    You figure, most boats use wood for stringers and reinforcement. If done properly those last for years (except for cheap boats where they take shortcuts):rolleyes:.
    Don
  22. wedjim
    wedjim
    from Kissimmee
    Glossing sounds like a great option! I will use that for my interior structure. For my door jambs, hinge areas and my dash I'm using metal for grounds and strength. Just makes sense I think?
  23. wedjim
    wedjim
    from Kissimmee
    This is after completing the dash mounts and column mounts, bracing. With components installed temporarily.
  24. Hot Rod Nut
    Hot Rod Nut
    You my Friend are right on. Done it this way 6 times and it works perfect everytime.
  25. cktasto
    cktasto
    Great thread. I've got a FG front end for my 55' and its got a really bad "swoop" in it. I've been thinking about how im going to take it out and this has given me some ideas ImageUploadedByH.A.M.B.1410323198.124514.jpg ImageUploadedByH.A.M.B.1410323232.324256.jpg ImageUploadedByH.A.M.B.1410323255.490831.jpg
  26. camerl2009
    camerl2009
    10 year old thread bump wow
  27. cptn60
    cptn60
    from Joke City
    beats gettin called out for not searching....
    madmike8, camerl2009 and cktasto like this.
  28. wedjim
    wedjim
    from Kissimmee
    Best way to get called out is to participate...in anything. :)
  29. wedjim
    wedjim
    from Kissimmee
    I did the back of my Vicky just today. Ready for interior trim, once the rest of the car is done.
    cptn60 likes this.
