Hello I bracket race a 58 Olds with a 371 and have just found a 394 and a B&M for maybe next yr or the yr after $$$$$. I am missing the 394 valve covers,oil flt adaptor, and maybe more when i go threw it all. I would like to know the formula for bore and stroke a 394 to 482,do i chew the light aftermarket pistons by my teeth or can you buy these done already? What light rod?,does eagle make a rod like a 425 or 400 7 inch rod for a 394? My B&M came with a chev ft. housing and small dia fluid coupling. The olds frt house is on there now and a slant pan Olds fluid coupling. The seller told me the vanes from both looked exactly the same when he swapped them. I heard there is a bigger stall speed with the larger Olds coupling anyway? But as per the B&M info i have read the Chev. coupling must be used? Niether were brazed. But this is suppose to be a intro so... My 1/4 mile times with a 58 88 371 4 speed hydro. @4240 pds. 15.288@90mph. Offy 3x2 intake,homemade in chassis headers,mild trw hi pro. cam(only one i could find),31 spline 64 caddy 342:1 posi pumpkin in the 58 housing(axles cut),MSD. I am gonna need some help this coming winter with. Thanks for you all being here. Good luck and drive safe Randy H. Arctic circle B.C. 58 88 J2 67 Cutlass 72 Cutlass Convert.(Windy) 72 Cutlass(Buick430)12.50 street car
Thats really cool to see a Olds still tearing up the quarter mile. Welcome to the HAMB. You might want to ask your questions on the main forum so more people will see it. Good luck.
