[[[[ brackets ]]]]
Discussion in 'The Hokey Ass Message Board' started by Del Swanson, Nov 25, 2008.
  1. Del Swanson
    Del Swanson
    from Racine, WI
    I did a search for "Brackets" and I didn't find a specific thread on this subject. I'm really interested in creative home-made brackets or anything that is used to mount or join things together. Lets see your handiwork. The best ones have more than one function. I'll start it out with my cup holder on my drawing table. It only serves one function, but it's an important one!
  2. belair
    belair
    Cool-this ought to be a good thread. If it gets down to coat hangers and duct tape, I'll have something to contribute.
  3. CJ Steak
    CJ Steak
    from Texas
    Cool cup holder man! I'd tap it and put a little bleeder valve on the bottom to let the condensation out. Althought tipping it would work just as well.
    Wish I had something to contribute... I may need to whip something up real quick!
  4. These aren't too exciting, but here's a few brackets I made.
    A fuel log bracket made out of 16 ga stainless (home-made fuel log and fuel lines too).
    A low-mount mini-alternator mount bracket out of steel plate and tube.
    And a throttle cable bracket for a tri-power setup I made out of aluminum.
  5. jaybee
    jaybee
    This ought to get good.
  6. Del Swanson
    Del Swanson
    from Racine, WI
    That's the kinda stuff I'm talking about! Very cool! Maybe I'm just a bracket geek.
  7. flynbrian48
    flynbrian48
    I'm pretty proud of the brackets holding the cycle fender(s) on my '36 Fordillac...well, the one I have done, anyway...:D
    alanp561 likes this.
  8. Del Swanson
    Del Swanson
    from Racine, WI
    Very nice Brian! Come on guys, I know there's a lot of talent on this board!
  9. Jibs
    Jibs
    I have two of these mounted on my 47 Chevy dash, they usually have Iron City cans tho. JJibs
    alanp561 and uncleandy 65 like this.
  10. Del Swanson
    Del Swanson
    from Racine, WI
    Come on guys, more cool stuff!
  11. tommy
    tommy
    my take on an old school generator bracket. My friends thought it was a carb restricter plate.:D
  12. Glen
    Glen
    Great thread...I hope this grows to about 50 pages. Its always a challenge trying to mount something. I usually think of El Polacko and Bass....and wonder "How would they do it"? and then when Im done think "Is anyone going to laugh at this?"
  13. yblock292
    yblock292
    Worse thing about Hot Rod bracket buiding is most of the time it seems like you gotta build 2 a right and a left! So you really make a kool shock bracket and then realize you gotta go copy it
  14. Paul
    Paul
    Editor
    bracket to mount clutch slave to lower bellhousing on early Olds
  15. COS
    COS
    from KCMO
    Man this thread is great!! Wish I had the tools to make some of this stuff!! Keep them coming!!
    -COS
  16. zman
    zman
    from Garner, NC
    yeah they should have some cool stuff to add.
  17. Del Swanson
    Del Swanson
    from Racine, WI
    BUMP, HAPPY tHANKSGIVING
  18. LabRat
    LabRat
    This is cool ..... Perfect way to mount your alt. , clean an out of the way .
    mind showing us how it looks from above ?
  19. a.y1320
    a.y1320
    This isn't mine but it is very cool. f1 steering box with an old vw van carrier bracket. He milled down the steering box and this bracket clamped down around it and also tied it to the frame. It looks freakin stock. Its on a really cool 32 coupe.
  20. Glen
    Glen
  21. Here you can see what my brother calls his "Holy Headlight Holder".
  22. Toast
    Toast
    from Jenks, OK
    Cool stuff guys!!
  23. LabRat
    LabRat
    Thanks Glen ...
  24. Kustm52
    Kustm52
    Steering box mount...
    Brian
  25. flatheadpete
    flatheadpete
    from Burton, MI
    Here's a submarine full of homemade brackets...
  26. gashog
    gashog
    I really had to tax my fabrication ability to make this one. I'm not much of a welder, so I use preformed shapes or bend metal with the torch whenever I can. The idler bracket is made from a single piece of 3" x 3" x 1/4" channel. I probably have a solid weekend in it including the mods to the generator housing, but it's worth it every time someone asks me if it's a factory Ford bracket :)
    winr likes this.
  27. Anderson
    Anderson
    Wishbone mounts. Couldn't find a finished pic.
    Headlight/Shock mounts
    Exhaust hangars.
  28. Glen
    Glen
    Radiator mount, its kind of like a bracket.
  29. Just a few things I've made to hang stuff...
    Not real pretty... but made to look like something Hurst would have made tp put a SBC into a '40 Ford to the stock mounts (w/o the "c" piece they used to provide)
    I get into making the edges of my brackets as smooth as the face... file, file some more... garnet... all by hand... it's the woodshop teacher in me. :) You can see it on the edge of this one.
    I also started rounding the heads of my bolts on my lathe...
  30. Sam,
    I often do the same thing with the bolt heads. You ever come up with a simple way to make sure they all come out exactly the same height (other than marking each bolt)?
