[[[[ brackets ]]]]
Discussion in 'The Hokey Ass Message Board' started by Del Swanson, Nov 25, 2008.
  1. roddinron
    roddinron
    OK, I'll play, nothing fancy here, just a simple oil filter bracket for a 235 chevy. BTW, I'm lovin' this thread.
    alanp561 likes this.
  2. Abomination
    Abomination
    Here's a couple of bed and cab adapter brackets bigtumtum made for his A.D. Chevy and posted in the Definitive S-10 Thread, which is at this link: http://www.jalopyjournal.com/forum/showthread.php?t=274702
    Granted, they're for An A.D., but they're easily modifiable to mount about anything you wanted to said ch***is.
  3. langy
    langy
    Some of mine
    Engine mounts
    Front spring perch
    Idler pulley
    Brake pedal pad
    Motor mount
  4. general gow
    general gow
    MODERATOR
    oh, i love this thread. such cool stuff. makes me want to head to the shop...
  5. Del Swanson
    Del Swanson
    from Racine, WI
    WOW beautiful stuff guys! Dan Webb's Submarine is what got me thinking about this thread. This stuff is pure artwork!
    Del
  6. sko_ford
    sko_ford
    heres my hurts moto mounts. kind ham fisted but they work. right now i'm still pondering a downlow mount for an alt on a pontiac 400
  7. Splinter
    Splinter
    Couple of mine-
    -Alt mount for a Nailhead (no holes anywhere on the front of the block)
    -Rad mounting
    -Motor mounts
  8. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Brackets to me tell a story.......they show how one solved a problem.......Littleman..
    The Fun Pedal Bracket......still needs finished..
    This is an older one as well and still needs finished...
    [URL=http://g.imageshack.us/img392/p1010170vs2
  9. Nope... I just do them by eye.
    Sam
  10. solid
    solid
    I love mounts, and brackets. Just love em!!!!!! I hope this thread goes forever.
  11. Gepetto
    Gepetto
    from Orange
    sam how bout some more pics of the trump?
  12. [​IMG]
    All wired, plumbed and running:
    Sam
  13. scottybaccus
    scottybaccus
    I got stuff....
    I made all of these by drawing the parts in a free cad program called Emachine Shop. The company that provides it uses it to sell simple parts made to order in quan***y. Lucky for me, it will export standard .dxf files that I give to my local CNC plasma cutting guru. I would tell anyone to go play with this program for a while. They'll get hooked.
  14. jdub
    jdub
    I used to think I was pretty good at this stuff until I saw the other pics posted. Doh! Here's my contribution anyway - '53 chevy steering column with power steering from Fat Man.
      131.7 KB
      120.4 KB
  15. Sellers Equipped
    Sellers Equipped
    from San Jose
    Alittle somN
  16. flatblackindustries
    flatblackindustries
    from Ogden, UT
    Steve,
    Your stuff is always insane, your thought process is out of this world!
  17. Del Swanson
    Del Swanson
    from Racine, WI
    Just because I said "home made" doesn't mean I didn't want professional shops to show off there talents! If it's made with your hands or is made using machines but is a one-off piece, Lets see 'em!
  18. scootermcrad
    scootermcrad
    Couple of mine... all one-off, as requested. Made with a cutting wheel, drill press and hole saw and welded up. No mills or special meachining tools. I WISH I had that kind of stuff. Nothing special, but was fun to make...
  19. Wyle E Coyote
    Wyle E Coyote
    Here are a few that I have pictures of that I have built for my latest project.
    I had 10 hours in making the tail light brackets and mounting them.
    The headlights brackets where a little easier, but still took a lot of time.
    I guess the tailgate hinge is a bracket, but it's something I'm proud of anyway.
  20. Wyle E Coyote
    Wyle E Coyote
    Here's another of the tail light mount
  21. flatblackindustries
    flatblackindustries
    from Ogden, UT
    Nice Scooter.
  22. My alternator adjustment and mounting brackets, just finished the timing pointer. All my milling, drilling, sanding and cutting done on a Shopsmith MK5.
  23. Did not want to cut up the original brake pedal so I fabbed this up.
  24. Sellers Equipped
    Sellers Equipped
    from San Jose
    everything you saw on that was cut by hand,, paper stencil, blue dye, used a plazma by hand to cut it out ,, sanded on a belt sander, machined little nut cover for the top, and bottom to hide the bolt, and cover to hide the rubber mount, 1st set I ever made, And I live in my shop.. soooooo can i still play.. ;)quote=delswanson;3342815]Just because I said "home made" doesn't mean I didn't want professional shops to show off there talents! If it's made with your hands or is made using machines but is a one-off piece, Lets see 'em![/quote]
  25. synchro7
    synchro7
    SanIyam,
    You might consider adding the piece behind and under the harmonic balancer. I built a set just like yours back in 1963. Had them on a 283 in a T bucket. The first time I dumped the clutch the bolts sheared clean off.
    waspmaj
  26. Del Swanson
    Del Swanson
    from Racine, WI
    [/quote]
    The only thing I meant by that is I didn't want to see m*** produced "cookie cutter" stuff. Even if you sell the stuff you make, if it's creative we'd all like to see it.
    Your stuff is kick-***, thanks for showing it!
    Del
  27. Wyle E Coyote
    Wyle E Coyote
    I agree. I like to see other peoples work for inspiration. It makes me want to build mine even better the next time when I see something like Sellers makes, it's like artwork.
  28. ash
    ash
    from Detroit
    My dad loved making brackets, braces and etc on the sub, as you can see lol
    It's what he's very creative at
    And I got tons of build pictures of all the build of the brackets and braces all done by hand... That is what makes a car those fine details
  29. Nick32vic
    Nick32vic
    I love this thread. Keep it going! I love creative but clean looking brackets. I made a pretty cool alternator bracket for the ****roach. Unfortunately I wasn't able to get it nice enough for chrome but it came out nice. I wish I would have taken a picture of it. I hope B*** posts a picture of his stuff. The generator bracket he made for his roadster is perfect.
