[[[[ brackets ]]]]
Discussion in 'The Hokey Ass Message Board' started by Del Swanson, Nov 25, 2008.
  1. Mat Thrasher
    Mat Thrasher
    I'll add one. Not much but I liked the way they came out. Motors mounts on my 34 olds.
    Mat
  2. Mike Britton here. May I borrow your idea for the exhaust braket to use on my '29? I've never seen any simpler or cleaner. Thanks, Mike
  3. WelderSeries
    WelderSeries
    Alliance Vendor
    Awesome thread!
    pic 1 is a re-purposed bracket, drilled out to hold the fitting on the end of a brake line... the round portion on the end of the hex presses into the hole in the bracket.
    pic 2 (top middle) is my brake pedal spring return/brake light switch depresser bracket. When I press on the pedal, the disc that's holding the brake light switch lets the switch open, turning the brake lights on.
    pic 3 is my e-brake handle bracket. ref. this thread for more info.
    pic 4 is a multi purpose bracket... the two round parts hold two a/c lines. I made them from two Kugel stainless line clamps, with the flats trimmed off and welded together. The lower stainless tubes run my ****** cooler lines to the radiator. I parted two stainless AN fittings in half, counter-bored them, and welded them to the 3/8 SS tubes. The bolts that attach the piece to the frame rail is right in the middle, so I'll be able to squish an allen key between the a/c lines to tighten them, but the lines will hide the bolt heads. The top tube is just a run for headlight wires.
  4. Halfdozen
    Halfdozen
    I'm putting a 292 inline six in a '40 Chev coupe. Wanted to run a SBC Fluidampr, don't have enough room ahead of it for V belt pulleys. So I machined a crank pulley that fits over the Fluidampr and has grooves for a six rib serpentine belt. Made up the necessary bracketry to rigid-mount the power steering pump, alternator, fixed idler pulley and tensioner. It all looks a little crusty in the pics, I haven't done final paint yet. Not traditional I s'pose, but an option when trying to fit all the components into a cramped engine compartment.
    I can supply more details if anyone's interested.
    X-cpe and alanp561 like this.
  5. Fishtail8
    Fishtail8
    Nice stuff on here guys! Here's my contribution. I had a bent front bumper on my car when I got it, and some aluminum stock lying around in the garage. A couple of days later I had two aluminum front bumper brackets, and lost 35lbs off the front end of the car!
  6. Del Swanson
    Del Swanson
    from Racine, WI
    That's going to look awesome on the car! I love the welder series stuff too! Thanks for sharing everyone!
  7. Graham08
    Graham08
    Here's my latest...for mounting a fuel cell on a racecar. Too bad it will be completely hidden when the car is together! :D
  8. Graham08
    Graham08
    Here's a panhard rod bracket on the same car. It uses the six bolts on the front of a quick change.
  9. Del Swanson
    Del Swanson
    from Racine, WI
    Come on guys, you don't have any hair on your rear ends if you can't show me any more brackets! Merry Christmas!
  10. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I like brackets that do more than one thing, like my front shock mount, head light mount and radiator mount bracket. You can also see the engine mount and the "bracket" that holds the top of the grill shell in place and mounts the puke can and also the fasteners for my hood sides.
    The other bracket is my front wishbone mount. Double shear and intergrated into the frame. The last one is my rear cross member that I fabbed so I could run a T spring.
    Rex
  11. fnjunk
    fnjunk
    from Australia
    Can some one post some more Nailhead brackets need some ideas..
  12. treb11
    treb11
  13. Concrete B
    Concrete B
    this deserves a bump!
  14. 19Fordy
    19Fordy
    Aluminum coil bracket on 8BA. Bolts to water pump using a longer water pump bolt.
  15. 41 Dave
    41 Dave
    Guys, There is some real creativity out there ! Like them clean and simple. The headlight/shock moun is one of my favorites !
    41 Dave
  16. brett4christ
    brett4christ
    Too cool to let die! Any more stuff out there?
  17. 26T
    26T
    from Denver
  18. 19Fordy
    19Fordy
    First pic is of a fan carrier bracket that swivels left and right to compensate for the 7/8in. offset when using an OFFY 4 bbl. intake on an 8BA. Second photo is a simple coil bracket that mounts to a water pump bolt on an 8BA.
    alanp561 likes this.
  19. 61bone
    61bone
    In progress k member and motor mounts.
  20. Bracket I made for a 60s Mopar steering box.
  21. rustypipes
    rustypipes
    from san jose
    Heres My ****** X member and bracket made for my chevy
  22. Mark H
    Mark H
    from Scotland
    Engine mounts for the 289 in my 'A'.
  23. Del Swanson
    Del Swanson
    from Racine, WI
    I love this stuff!
  24. Slag Kustom
    Slag Kustom
    i kinda gave up on brackets and just make the part with the bracket built in.
    clutch slave cylinder
    ac bracket
    steering box
    carb linkage
    caliper mounts
    trans mount
    gas pedal
  25. Del Swanson
    Del Swanson
    from Racine, WI
    Beautiful!
  26. choke
    choke
    This is a neat thread! I love seeing everybodies work. There's alot of talent on this board.
  27. Martin_F
    Martin_F
    Motor mounts on my 36 truck:
  28. Morrisman
    Morrisman
    from England
    Not very clear photos, as I only had a ****py digital camera back then, but here's a few of mine
    An adjustable rubber mounted motor torque arm I made for a Buick 215:
    A flowed adaptor to fit a carb onto another manifold. CNC machined (with a file and flap wheels):
    Alternator bracket, made from s**** flat bar:
    Various suspension bracketry:
    Shock/light mounts, fabbed from s**** stock:
    Quarter elliptic leaf mounts:
    A whole bunch of hand fabbed stuff, everything, in fact, on my V8 bike:
    And my coupe project:
    Remote oil filter manifold, whittled from ally:
    Removable ****** cross member:
    Front fender mounts, from 1/2" round bar:
    Panhard rod mount, ch***is cut-outs and headlight/shocker mounts:
    Some firewall hardware/framing:
    Early days on the ch***is parts:
    And four bar brackets:
    Basically, I love making this sort of stuff, fine tuning the detail and design. It is what makes or breaks a project: the details. My stuff sure ain't show quality, but it usually does the job, properly.
  29. langy
    langy
    Here's a bracket i made to hold my door mirrors
  30. need louvers ?
    need louvers ?
    Wow I don't know how I have missed this thread. And, yes I wish Steve (Elpolacko) would post on this with some of his stuff. You know what ****s about having a friend on that level as far as design and fabrication? I can sit and design and build a bracket (after a couple of templates, of course!) execute the build on a level that's perfect. Then, most folks most folks looking at it will say, "man that's cool!"... And he'll walk over and say, "Neat, but if just had done this, it could have done this, this and this! God I hate overly talented friends!!! I will post some photos of my stuff in the next day or so.
