Braided rubber fuel line
Discussion in 'The Hokey Ass Message Board' started by willymakeit, Feb 25, 2013.
  1. willymakeit
    willymakeit
    I bought some fuel line that has a fabric braided sheath. It is the same stuff used on large trucks. However for some reason I cannot bet it to go on over standard fittings. It will go on part way and just stop. Any suggestions? Ive tried lube,cutting off the bulb on the metal fittings.
    Id like to use it as the perormance[life] is supposed to be very good.
  2. lht
    lht
    wrong size line?
  3. willymakeit
    willymakeit
    Nope ,wish it was that easy. Thanks tho.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Are you sure that hose wasn't intended for use with AN fittings instead of the barbed fittings you are trying to use ?
    Don
    When you say braided, this is what I envision:
    It is not made for regular hose barbs, but goes with AN type fittings.
    Like these:
  5. 19Fordy
    19Fordy
    Photos please ? Usually, lubrication helps.
  6. tedley
    tedley
    from canada
    I put braided lines on my rpu over 30 yrs ago with AN fittings and are now illegal around here to use. Not DOT they say. Never seen braided DOT lines. May want to check on that first.
  7. That's what she said! :eek: :D
    Sounds like you've got fuel injection hose there. ;)
  8. BigPerm365
    BigPerm365
    As a truck parts guy....you can use the fabric braided hose for fuel, but it's really not designed for hose clamps. Depending upon the brand, you can buy re-useable screw-on fittings that work fine. Problem is; finding a truck shop that carries all the fittings yer gonna need. I'd try Peterbilt or Kenworth. Failing that you can go to a hose shop....but will pay much MORE for Parker-Hannefin or Stratoflex brand fittings. We us it for fuel, air & P/S hoses.
  9. cmyhtrod
    cmyhtrod
    from ct
    I think Don is spot on, wrong combination of fittings and fuel line.
  10. 27 tallt
    27 tallt
    ;)I've used what I think you have and that is, a fuel line that is neoprene, but has a braided cord in its composition. They can sometimes be a *#?^*&% to put on. What I have done in the past is used a heat gun. Heat the neoprene up well and try that. I would suggest using some gloves as the rubber has a tendency to get really hot and is hard on the fingers. Just my 2 cents.
  11. willymakeit
    willymakeit
    Don has it right. Im going to have to see if there are adapters. I bought from a truck supply house not to far from me.
    It will start on normal fittings but doesnt give me thefeeling that everything is working right.
    I just dont want to re do any thing as the routing is tight and I have put extra protection on in these areas. Thanks for the help and ideas. Im going to try everything posted and see how it works out.
