Projects brake article
Discussion in 'Traditional Hot Rods' started by Vern Lee, Dec 25, 2021.
  1. Vern Lee
    Vern Lee
    Can anyone tell me the axle shaft where the rear axle bearing goes dimension ? I'm putting 1940 brakes on my 31 model a , my A axle checks 2.065 , my bearing # 68-1225-A checks 2.095 , seems pretty slopy to me , What do you think ?
    Vern
  2. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I have '40 brakes on my '29 A-V8. When I put them on I didn't have any way to measure the bearing to axle size and I couldn't find the info I needed.. I just stuck 'em on there without the seal and gave a little effort to wiggle them and they seemed okay. I've been driving it for a couple of years and haven't noticed any problems at all. I ordered new seals and was asked if it had been converted to hydraulic brakes. I said yes. The seals came and they so much smaller I couldn't believe it. The package said they were what I expected but the seals were not even close. My best advice is to do as I did. Put the hub w/bearing, no seal on the the axle, snug it up and see if you can detect any up/down, side to side movement. Use the '40 seals and bearings. Don't forget the fiber washer that goes under the axle nut.
  3. Vern Lee
    Vern Lee
    Thanks Glenn , I think I will just put them on and see what I end up with
