Technical Brake Bleeding Problem - 39 Ford
Discussion in 'Traditional Hot Rods' started by Geejay, Aug 16, 2023.
  1. bobss396
    bobss396
    I like to bevel the leading and trailing shoe ends with a wood rasp. It gives the shoes a little head start on conforming to the drums.
  2. clem
    clem
    I didn’t even know about bench bleeding until I came to this forum. Still never done a bench bleed of new master cylinder, - although I have only done a few………all under floor ones.
    I still don’t understand the logic to it, as surely at some point the air bubbles rise to the top, bit like air you breath out under water ?
  3. alchemy
    alchemy
    I always thought that as soon as you break a connection you will introduce air into the system. Take the little lines off after you do a bench bleed and screw in the new ones, and there’s got to be a bit of air that lingers in the ports. Maybe even migrated to the main bore.
    Always sounded like a waste of time.
    clem likes this.
  4. bobss396
    bobss396
    I had changed a brake light pressure switch, did not have to do any bleeding after. Pedal was where it was before I took it apart.
  5. clem
    clem
    yep, I have had the same, but it was directly hooked into the tee on the master cylinder, so possibly the air went back up to master cylinder or I didn’t notice the small amount of air in the system………
    After several hydraulic switch failures, I went mechanical switch……..
    bobss396 likes this.
  6. bobss396
    bobss396
    I am on my 2nd switch in 7 years, the 1st was from Napa, pure garbage. Almost anything from Napa has "soiled" the bed on me. Mine is south of the master, installed into my distribution block. I have a spare pair of wires into the switch bundle in case I want to go with a switch on the pedal arm.
