Hot Rods Brake bleeding woes
Discussion in 'The Hokey Ass Message Board' started by Randall Strickland, Nov 14, 2025.
  1. I have a 52 f1 that someone put a Fatman M2 ft suspension under with 78-85 GM calipers,I bought this truck 18 years ago from a friend, the brakes have always been soft but it would stop, the master cyl went bad so I replaced with a new 85 mustang thats what it had ,the master cyl and booster are mounted under floor, I have tried two different new master cyl and a new distribution valve and can not get a pedal, tried the pump up and hold bleeding and also air vac bleeding letting the calipers hang down lower than M C and also above, has anyone else had this problem? I have also checked booster to make sure the plunger is coming out far enough
    Toms Dogs likes this.
  2. partssaloon
    partssaloon
    Did you bench bleed it first?
  3. AldeanFan
    AldeanFan
    Which ‘85 mustang master did you get, there are at least 3 different ones.
    SVO/SVT is for 4wheel disk brakes and won’t work with front disk/rear drum.
    There are also multiple bore sizes later foxbodies had 3 outlets.
    Do you have residual valves? ‘85 mustang master would not have them because the master sits above the calipers.
  4. 19Eddy30
    19Eddy30
    from VA
    My self I have never used the residual,
    All mine are under floor master
    with dic.
    When comes to bleeding ,
    There been a few Dic & drums been a pain , I have used different techniques
    I have found when using a vac bleeder
    Its best to have a ***ortment of bleeders with the nose cut off or dill hole in end
    So when you screw in it seats & does not **** air @ thread & make sure tight fit
    On rubber boot , & sometimes do not pull full Va*** , when bleed add original bleeder in.
    Then with no help & vac bleeder
    A liter bottle 1/4 full brake fluid
    Same with bleeder with hole in
    Rubber hose Clear more desirable
    Pump brakes Slow & steady ,
    Taken 5-10 to push to floor full puddle stroke , & 5-10 sec back to rest .
    Also I have installed tire rim steam
    In master cylinder top & pressure the master cylinder with 5 psi with slightly cracked bleeder .
  5. pprather
    pprather
    I'd also start asking, did you bench bleed the new master?
  6. Toms Dogs
    Toms Dogs
    from NJ
  7. 1971BB427
    1971BB427
    from Oregon
    Holding the calipers down lower than the master didn't help bleed the system, it only complicated matters. The air in the system wants to rise, so calipers need to be higher than the master to eliminate air, not lower.
    And as others said, did you bench bleed the master first?
    Also, you should have someone gently push the pedal down as you break the fittings loose at the new master to get any air trapped at the outlets out first.
  8. Are they the low drag calipers? Much has been written about the issues they cause unless you use a master cylinder designed for them. The other solution is to switch out the stock low drag GM calipers to an aftermarket version without the low drag (Speedway sells them for example).
    boxerdog, VI Lonewolf and RMR&C like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
  10. Happydaze
    Happydaze
    Distribution valve you say? Isn't there something that needs to be done with those when bleeding? Some kind of reset, or is it a replacement part installed during the bleeding process? I've never done it, never had such a valve but am aware there's a peculiarity with them, just can't recall exactly what!
    Chris
    05snopro440 likes this.
  11. If you have a safety valve in line, there is a plug with a Pin in it to keep from moving the barrel valve and blocking one port. Very Few home mechanics think about that till it's too late.
  12. Thanks to all
    Yes I bench bleed master cyl
    master cyl is for a v8 fox body not a svo
    I've did everything like 19eddy30 except modifying bleeder but I had give it a thought so thats my next try
    the cover is really close to floor , I have to take a mirror to see fluid level, going to do like 19eddy30 and install a tire valve in cover if I have room
    Also have the distribution block pined so spool can't move
    Don't know if caliper is low drag the part number is 18007150 and 18007151
    Pist-n-Broke likes this.
  13. AldeanFan
    AldeanFan
  14. Kevin Ardinger
    Kevin Ardinger
    Calipers on backwards? Are the bleeders on the top of the calipers?
    Pete Eastwood and pprather like this.
  15. 19Eddy30
    19Eddy30
    from VA
    @Randall Strickland
    All so , did you install any new
    Inverted fitting or pre made hard lines?
    Just asking I have encounter many new OFF BRAND , ( Autozone ect) inverted fittings & premade lines the cone / taper shape is not correct and will **** air and sometimes not leak Fluid , my fixes to have multiple old br*** fittings and OEM to reshape the cone /taper correctly and I even have a $200 Master cool die kit
    & typical bench vice style also
  16. kabinenroller
    kabinenroller
  17. Based on what I've seen, those are the metric low drag calipers...check out the following thread. You need to change the calipers as I said before, Speedway sells a version of this caliper that is not low drag (I have them on my '32...they work) as does Afco (part numbers in the thread below). Or if you want to keep those calipers you need a stepped bore quick uptake master cylinder designed for use with low drag calipers. It's been discussed many times on the HAMB...see the following as an example.
    https://www.jalopyjournal.com/forum/threads/gm-metric-low-drag-calipers-fixed.1202460/
    VI Lonewolf, boxerdog and 05snopro440 like this.
  18. 05snopro440
    05snopro440
    You're correct, IF it's a combination valve they have a piston that slides back and forth that needs to be locked out for bleeding. If one side loses pressure, the piston slides that way and blocks fluid.
    I have the little tool from my CPP kit on my 62 Bel Air. It's a plastic piece with a long snout that threads into the combination valve and holds onto a groove on the piston.
  19. I think the problem is the low drag calipers, what master cyl has anyone used with the low drag calipers?
    the m c I have is mounted with reservoir pointing to rear with lines on driver side, just wondering if theres another replacement that would fit my booster and work with the low drag?
  20. The master cylinder would need to be from a vehicle that ran those calipers...metric era GM F or G-Body, I believe the s10's of the era. I can't tell you if it'll work with your mount and booster. If it were me, I'd keep the master cylinder and change the calipers.
    VI Lonewolf likes this.
  21. RMR&C
    RMR&C
    from NW Montana
    I used a step bore master for a mid 90's S-10. It has the lines on the other side though, I think all GM masters of that vintage do
  22. Splitbudaba
    Splitbudaba
    I back bled and down bled mine. Make sure you have a good pump can that won't add air. I also used silicone based fluid, won't eat the paint, works great!!
    A piece of clear hose on the pump can will tell the tale.
  23. Pete Eastwood
    Pete Eastwood
    from california
    Look at where the bleeder is on the caliper.
    If the ****** on the bleeder is pointing up the caliper is on the wrong side.
    The bleeder should be nearly horizontal
    It's not how high the ****** end of the bleeder is, it how high the seating end of the bleeder is.
    Splitbudaba and Royalshifter like this.
  24. I've found that if using a vacuum bleeder, by taking the bleed screws out and wrapping a couple of layers of teflon tape on the threads only then screwing them back in makes a world of difference...
    You'll never have any issues with them seizing either.
  25. Ok bought the afco calipers and they have 5.5 bolt spacing my old ones 7, so got to do something different"
    old caliper pt no, 18007151 and 18007150 not sure if they are low drag or not
