Hot Rods Brake booster Boot
Discussion in 'The Hokey Ass Message Board' started by tack, Apr 26, 2022.
  1. tack
    tack
    from Wisconsin
    Can I install a power brake booster without the rubber boot? It's too big to fit through hole in my brake pedal bracket. Is it's purpose just to keep dirt out? It fits if I leave it off. Thanks.
  2. X38
    X38
    Make the hole bigger.
    Happydaze likes this.
  3. tack
    tack
    from Wisconsin
    I'm using a wildwood swinging pedal that can't be bored out big enough. It worked for the manual setup. I would like to keep using it because I had to do quite a bit of fabrication to mount it under the dash of the '47 Desoto.
