Brake calipers...
Discussion in 'The Hokey Ass Message Board' started by convict, Feb 24, 2013.
  1. convict
    convict
    from laredo,tx
    Has anyone seen the brake caliper,set up in front of disc instead of the usual placement .... Is this safe.
  2. 40FordGuy
    40FordGuy
    I believe that as long as you keep the bleeder port on the top, and your flex lines clear everything that moves, it shouldn't make any difference.
    4TTRUK
  3. gimpyshotrods
    gimpyshotrods
    Seen it, done it. No issues. Bleeders up!
  4. DAVEG2
    DAVEG2
    Mine are in the front on my vintage stock car. No problems in 10 years.
  5. Morgan91
    Morgan91
    from Australia
    Yep, some cars come out with them on the front. Doesn't effect it at all, might just have to swap left and right calipers over to have the bleeder on top as mentioned above.
  6. convict
    convict
    from laredo,tx
  7. JEM
    JEM
    Some manufacturers like leading calipers (in front of the axle, front or rear), some like trailing calipers (behind the axle). It just depends on where their suspension design leaves them room to put the caliper.
    Note that many modern multipiston calipers have staggered caliper bores, where the piston sizes vary, so in general you cannot swap these calipers from side-to-side to move the bleeder screw to the top without causing yourself pad-wear problems; typically the bleeder screws will swap places with the transfer tube.
    Not completely HAMB-material, but this is an '05 Porsche Cayenne caliper (RH leading in the Porsche application, RH trailing for my '64 Galaxie...) with the bleeder screws and transfer tube swapped.
  8. Lots of OEM calipers are up front ( leading)
  9. zjerry
    zjerry
    X2 They came stock like that on my 2005 Monte Carlo SS
  10. lht
    lht
    you can run bleeders on bottom i do it all the time on bikes you just have to take caliper off and hang upside down stick a peice of wood or what ever between pads when bleeding when done push pucks back and install
  11. HellsHotRods
    HellsHotRods
    Is this what the HAMB is today?
  12. gimpyshotrods
    gimpyshotrods
    Being able to stop your car as fast as all of the other cars on the road, without hitting them, is traditional.
  13. BORRACHO13
    BORRACHO13
    from Menifee CA
    Where I work I see front and rear mounted calipers on front rotors are used. Should work.
    Why do the bleeders have to up? Jus askin
  14. BarryA
    BarryA
    Air bubbles rise in liquid, you need to get the air out of the system for them to work..
  15. HellsHotRods
    HellsHotRods
    Mechanical brakes adjusted and set properly will stop a hot rod just as fast as modern cars. Anyone who has done it correctly knows this.
  16. Disks are ugly.
  17. Weasel
    Weasel
    Pure genius....:rolleyes:
  18. alchemy
    alchemy
    The cylinder of my disk brakes is right at the top.
    I hope they are traditional enough for this website.
  19. alchemy
    alchemy
    The safety of steel, from pedal to wheel.
  20. Mr48chev
    If you read what he wrote it was his way of giving a simple explanation to the question including a disclaimer stating that it was not HAMB Friendly. Some times the "Trad police" are more interested in being ***holes than they are in seeing what the posters intent was.
  21. seb fontana
    seb fontana
    from ct
    X2...And I'd bet he didn't know what the other red brakes [post #18] are; which probably raised a bunch of eyebrows!!!
  22. JEM
    JEM
    I had occasion a few years back to watch a couple Type 35 Bugattis go around Laguna Seca at a pretty astounding pace.
    Of course, I also recall my mother's stories about driving her family's '36 Ford to high school, in winter thawing out the brake linkage with a blowtorch before going anywhere...
  23. JEM
    JEM
    I have to ask though: do Kinmont brakes have any benefits other than novelty? That in itself can be enough as long as they work as well as a drum, I guess, but they're one of those things that came and went overnight.
    Speaking of stuff that came and went, I thought (very briefly) about swapping discs onto the '37 Chevy Dubonnet front suspension I'm working with for the project-after-the-next but concluded I'd stick with the Huck drums, we'll see what it takes to put Huck rear backing plates on a Ford 9in...
    Another oddball disc design (though not so much so as the Kinmonts) and decidedly non-HAMBable so I'll just post a link for the technically curious: http://ranwhenparked.net/2009/11/17/what-lies-beneath-audi-ufo-brakes/
  24. Kerry
    Kerry
    No but this is. Notice the Airheart disk brakes.
  25. gimpyshotrods
    gimpyshotrods
    Keep living the dream, brother.
    I live in the land of the billionaire driving the super-car. I can't afford to carry enough insurance to cover rear-ending a $300,000 car, with a lawyered-up multi-millionaire, or billionaire at the wheel, with 24-pistons gripping giant discs, managed by ABS, digital stability control, and abundantly poor driving skills.
