Projects brake choices
Discussion in 'The Hokey Ass Message Board' started by CHOPTOP_T, Sep 21, 2008.
  1. CHOPTOP_T
    CHOPTOP_T
    from place
    ive got a 35 ford i beam axle with 35 spindles. which year of drum brakes would bolt directly on? if there even is a such thing. im simply just tryin to find the cheapest easiest way to do so. i seen disc brake kits but there like three hundred bucks. i think i might be able to do better cant i?
  2. Hey CHOPTOP T,
    Here's a link to a thread I opened Tuesday asking essentially the same question. I got some good reply's. I plan to buy the bracket kit from lonewolfstreetrods to stick disks on the front while I gather parts for a drum set up. What are you planning to use the '35 front end on?
    http://www.jalopyjournal.com/forum/showthread.php?t=294683
