brake/clutch m/c assemblies
Discussion in 'The Hokey Ass Message Board' started by ct, Apr 18, 2007.
  1. ct
    ct
    from minnesota
    I need some help finding a clutch brake combination the will work off the firewall. I'm thinking I won't have enough space to run a traditional setup under the floor. I looked at some of the fancier companies (wilwood,master brakes) but was wondering if there might be another place to look. I'm running drums all around. Maybe not so much fancy as ugly and dirty?
    Thanks
    CT
  2. 53sled
    53sled
    from KCMO
    Look into a mini truck or nissan car (sentra, 240) for small, easy to adapt units, or make your own. (I stole this from a tech thread)
  3. Phil1934
    Phil1934
    Do you want dual reservoir brakes or can you use a Chevy PU brake/clutch MC? If so, Transdapt, Tardel etc. have pedals.
  4. t-town-track-t
    t-town-track-t
    from Tulsa
  5. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Phew, those are pricey, but I'm gonna start checking volkswagens at the junkyard. I don't think that's a bad idea at all. Did they ever go to a dual master?
  6. BJR
    BJR
    Check out the bore size of the VW master, I don't think it has enough volume to work American drum brakes. The wheel cylinders on American iron take more fluid then the tiny VW ones. Brian
  7. john56h
    john56h
  8. Shoebomber
    Shoebomber
    from Bangor, ME
    i'm looking for an underfloor, but everything is upwards of $400...
  9. Shoebomber
    Shoebomber
    from Bangor, ME
    why wouldn't there heavy duty work? It has a 7/8" bore... which is a little shy of, say, a Mustang master cylinder's bore of 1". I'm looking for something to run in my '51 Ford... I'll be running front discs with whatever stock drums came on the Ford 9" out back. Would it just not be enough pressure? I don't want to run a power booster or a hydroboost (no power steering, manual rack and pinion)...
  10. scootermcrad
    scootermcrad
  11. Shoebomber
    Shoebomber
    from Bangor, ME
    Anybody know the bore diameters of the Pete & Jake's Model A kit?
  12. lik2writ
    lik2writ
    from NY
    Search the posts for swing pedals, a few recent discussions and there is a pretty descript one, think under Tech along with plans and current parts #'s for brake cylinders and slaves .
    Also, Summit is carrying transdapt the swing pedals really cheap, ( under 75 ) but, right now the quality of recent transdapt stuff isnt that good, so beware. All the metal used thinner than their older stuff from not too long ago. Don't know if they've improved on what Summit is selling.
  13. scootermcrad
    scootermcrad
    Just received a tilton catalog in the mail and I have to say I'm very impressed with the products that they're selling. They have a direct firewall mount applications as well. I'm thinking very seriously about going with them. They have some other pretty unique looking setup possibilities as well that I haven't seen anyone else offer.
    Keep us posted on what you decide to go with and how you set it up. I would really like to know. I think brakes are a really good topic around here and the subject is worthy of it's very own tech section based on the fact that you can set brakes up a thousand different unique ways!
  14. Ole Pork
    Ole Pork
    I've got the same problem, and I went on epay last night and got a nice nova set-up dirt cheap. There were a lot of postings for small units like you're looking for. Give it a shot. Look under"master cylinder" and "pedals". You should be able to find something that w/do the job. Good luck....Ole Pork
  15. cwatson1953
    cwatson1953
    actually.....thats really cool looking....if only i could adapt that to my '53.....hmmmm....
  16. screwtheman
    screwtheman
    Wilwood has a double pedal setup that uses their modular master cylinders. I really like the clean/racy look they have on the firewall.
    But I've also heard a S-10 pedal ***embly is pretty easy to rip out and use as well.
  17. Shaggy
    Shaggy
    from Sultan, WA
    early 60's chev trucks have a nice set up and f-1's aren't bad either both traditional too
  18. flamedolds
    flamedolds
  19. 53sled
    53sled
    from KCMO
    it's so easy to put a dual reservoir behind the stocker, I had it done in a few hours, starting from scratch. If you bought the filling station's kit, it would be faster, but more $. I used 10 gauge s**** sheet steel.
  20. scootermcrad
    scootermcrad
    Anyone have pics of a hanging setup with cowl steering?? Specifically with a Schroeder sprint box?
  21. ct
    ct
    from minnesota
    This took me too long to get back to the thread. I went with the pedal set up from Stock Car Products. It wasn't too pricey and I think it has a good rough look to it. I used Wilwood m/c's mounted on the firewall. It isn't traditional, but I just wanted it to work. This was really easy to do. If anyone has any questions, I'm more than happy to p*** on any of my limited knowledge.
  22. jason12872
    jason12872
    I run drums brakes all the way around and a hydraulic throwout bearing in my Model A truck. I used a Willwood Dual Master cylinder for my brakes and a single for my clutch , I used Willwood floor Clutch Pedal ***emblies with some pedals I made. It's a nice compact setup.
  23. C4 Metal Werks
    C4 Metal Werks
    Run an Anson style set up with an ealy 60's Chevy truck clutch/brake cylinder.
  24. evil1
    evil1
    i shortened a stock 1963 c10 ***embly
