Technical Brake cylinder fitting
Discussion in 'The Hokey Ass Message Board' started by sheparj2, Jan 14, 2024.
  1. sheparj2
    sheparj2
    Does anyone know what kind of fitting goes in here? It’s a 1960 Cadillac rear end, threads are 7/16-20. When I look in there it’s like a funnel shape, not a volcano….
    thank you
  2. Not a fitting but style of brake line flare,,
    Google ISO bubble fitting ID. And tube nut to suit.
    May be called something different over your way.
  3. squirrel
    looks like it takes a bubble flare. It's probably not original...
  4. All these years and never heard it described correctly as a bubble flare.
    And DIN,in my world that’s metric
  5. squirrel
    If the thread is 7/16-20, then it's NOT a DIN fitting. Probably takes a normal US thread nut, and just don't do the last step of making a double flare.
    Barrelnose pickup likes this.
  6. Beanscoot
    Beanscoot
    Weird... inverse flare is 7/16-24 or 1/2-20.
    My 1964 Cadillac used 1/2-20 conventional inverse flare.
  7. sheparj2
    sheparj2
    Ah. Thank you. I’ll give the bubble flare a shot. Much appreciated.
  8. Double check the tube nut thread, measure once and all that.
  9. sheparj2
    sheparj2
    The plot thickens... I found a pic on ebay of 1960 Cadillac cylinders. One shows a copper washer and one shows sometype of copper fitting down in the hole. I just don't get it.
  10. In the picture of the two side by side, that copper / br*** seat in the hole is a seat for an inverted flare.
    If I was you I would go to a real live parts store and see what they have or can get. I suspect the right wheel cylinders will accept a normal inverted flare (double flare).
    sheparj2 likes this.
  11. justpassinthru
    justpassinthru
    1960 Cadillac had a flex hose from the rear wheel cylinders to the frame, both sides, then to a steel line.
    Go to Caddydaddy.com and look up the wheel cylinders and hose.
    Bill
    tb33anda3rd, sheparj2 and squirrel like this.
