Technical Brake Difference
Discussion in 'The Hokey Ass Message Board' started by seb fontana, Apr 28, 2023.
  1. seb fontana
    seb fontana
    from ct
    Typical drum brakes are a drum with with brake lining on shoes, What if the lining was on the ID of drum and the shoes were plain metal? Difference in braking ability?
  2. They would fade really fast, the drum is a better heat sink.
    Paulz, BJR, squirrel and 2 others like this.
  3. 05snopro440
    05snopro440
    I would think it would be harder for the waste wear material to be removed during operation as well.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    See how it works is. The train leaves not the station.
    '34 Ratrod likes this.
  5. squirrel
    Did you ever try to stop a truck using the transmission mounted band type parking brake?
    CME1 and jaracer like this.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    Where would the heat go?
    05snopro440 likes this.
  7. seb fontana
    seb fontana
    from ct
    No never had a truck with band parking brake. Don't think the same, band brakes can be very self energizing.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No gearing involved when brakeing at the wheels. That said, when I was in wood working we had a 48” wide 3 drum sander. Each drum had it’s own band brake. That thing would stop those drums in a heart beat.
  9. Budget36
    Budget36
    I realize Seb is just thinking outside the box, but with lining on the drum, it’s possible it would have a balance issue.
    The lining would still need to be replaceable as would the “shoe “ metal. And probably thicker material as well.
    Seems like a complex way for a drum brake setup to work.
  10. Probably minimal and momentary advantage. Once some heat builds up there will be a marked loss in braking ability.
    Cost of wear parts, design challenges mounting lining materials to drums
  11. Kerrynzl
    Kerrynzl
    It would work better if the friction material is on the side of the drum, and to prevent flex put more friction material on the other side to get clamping loads working against each other :D:D:D
    Come to think about it, I just described a disc brake
  12. Mr48chev
  13. warbird1
    warbird1
    One of the aircraft I used to work on had brakes designed like this which were cable operated. They worked, sort of, but the Cadet only weighed about 1100 lbs. so even though marginal they would slow the airplane down. But you really had to stand on the pedals to do so...
  14. seb fontana
    seb fontana
    from ct
    Kinmont brakes?
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No. Train = drum and station = shoe’s.
  16. seb fontana
    seb fontana
    from ct
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
  18. seb fontana
    seb fontana
    from ct
  19. chickenridgerods
    chickenridgerods
    from DSM, IA
    Gibberish.
