Technical Brake Drum Paint
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Nov 15, 2025.
  1. ‘28 RPU
    ‘28 RPU
    I am looking to paint my new Lincoln brake drums and I am wondering what paint I should use. I’m looking for gloss or semi gloss black and hopefully something that can build up some thickness to minimize chipping. The high temperature paints that I am familiar with leave such a thin layer of paint that it really doesn’t give much lasting protection.
  2. ***Area-51***
    ***Area-51***
    from Ohio
    Rustoleum has worked well for me.
    Oneball and MojoRacing like this.
  3. Bugguts
    Bugguts
    I’ve used Rustoleum.
    POR 15 and
    My last ones I painted with the same black single stage I painted the suspension with.
    U-TECH U350. Very economical, and tuff as nails.
    winduptoy likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    DUPLI-COLOR 12OZ FORD SEMI-GLOSS BLACK ENGINE PAINT (DE1635)
    warbird1 and winduptoy like this.
  5. MojoRacing
    MojoRacing
    Rustoleum here too. I mix a little bit of Flood Penetrol in and it will come out slick with a high gloss. Takes longer to cure but works great and easy to touch up with chips and scratches.
  6. ‘28 RPU
    ‘28 RPU
    I’m concerned about the high temperature damaging the paint. Not a real concern? I have no idea how hot brake drums can get (I learned that they can get hot enough to burn your hand).
  7. ***Area-51***
    ***Area-51***
    from Ohio
    Heat has not been an issue with Rustoleum,
    if your brakes are getting hot enough to damage the paint under normal driving conditions there is probably something else going on either brakes or bearings...
  8. HOTRODPRIMER
    HOTRODPRIMER
    Regular rattle can paints can withstand temperatures up to 200 degrees, Rustoleum hi heat paint can withstand tempertures as much as 2000 degrees.
    I have used regular spray paint on brake drums for years with no problems. HRP
    winduptoy and ***Area-51*** like this.
  9. lostn51
    lostn51
    from Tennessee
    X2 on the engine enamel and Rustoleum
  10. 19Fordy
    19Fordy
    Bar B Q spray paint.
    lostone, downlojoe33 and winduptoy like this.
  11. RICH B
    RICH B
    Rustoleum appliance black epoxy spray cans; tough and looks good.
  12. stuart in mn
    stuart in mn
    That's my feeling as well. I think in normal driving use they aren't going to get that hot. If you live in the mountains, or drive like a maniac, your results may be different.
  13. rusty valley
    rusty valley
    No need for high temp paint. I would paint them like the car, epoxy primer and real paint, not rattle cans. I would guess they have some sort of rust preventative on them so they don't rust on the shelf, clean that off. Rattle cans are for kids, like Trix
  14. uncle buck
    uncle buck
    How about brake caliper paint? Duplicolor and others offer that
    lostone likes this.
  15. Wobbly
    Wobbly
    from Ireland
    Rustin's ASAP satin black for me. Never had it flake on drums or calipers. Doesn't need a thick gloopy coat to give good opacity. Oh and its very quick drying
  16. 1952henry
    1952henry
    I used Duplicolor flat black engine paint on nephews off topic Mustang drums, just because of the wheels. 2 years of summer in town driving. Looks good still once dust is wiped off.
