Technical Brake drum removal…
Discussion in 'The Hokey Ass Message Board' started by rustydusty, Apr 26, 2024.
  1. brading
    brading
    Looking very carefully at the picture I am sure that is a 2 piece Hub and Drum. You can see the serrations in the hub and not the drum. Once you take the hub/drum ***embly of the stub axle you will see for sure. If I wanted to seperate the two this is how I would do it
  2. brading
    brading
    rustydusty and nochop like this.
  3. nochop
    nochop
    from norcal
    brading likes this.
  4. rustydusty
    rustydusty
    nochop likes this.
  5. Rusty O'Toole
    Rusty O'Toole
    If it's the front you don't even need to take off the wheel. Loosen the hub nut, give the wheel a wiggle and the bearing will pop out. Take the hub nut off, remove the wheel bearing and set aside. Now you can pull the wheel, hub, drum and all. This is easier than taking off the drum without the wheel.
