brake grabbing solution needed
Discussion in 'The Hokey Ass Message Board' started by bobwop, Jul 14, 2012.
  1. bobwop
    bobwop
    from Arley, AL
    In the past few months, we have had not one, but two Fords (51 and 53) give us fits with a grabbing brake.
    Both cars had the left front wheel grabbing causing a hard pull to the left.
    We bled, adjusted, replaced hoses, replaced wheel cylinders...and never did get to the bottom of it.
    One guy suggested we may have had the shoes on wrong...front on rear and rear on front. But we did not have the opportunity to make the switch.
    both cars HAD been just fine, then went into storage (over one year) and when they emerged, we had the problem. So it is likely related to a long term storage situation.
    any ideas, suggestions, solutions is appreciated!
  2. tb33anda3rd
    tb33anda3rd
    sounds like a coincidence to me. did you pull them apart to see what they looked like?
  3. 1950Effie
    1950Effie
    from no where
    I would have bet the brake hose flaking off inside keeping fluid from flowing back to MC. How about the return springs? Have you replaced them?
  4. TheTrailerGuy
    TheTrailerGuy
    Just my two cents, but i don't think that I ever drove anything with drum brakes that didn't do a little 'yankety yank' one way or the other. I am going to watch this thread because i want to know what i have been missing all these years.
  5. bobwop
    bobwop
    from Arley, AL
  6. dtracy
    dtracy
    Have you looked at the right front brake? Sometimes if a piston sticks on one side it pulls to the opposite side. Just a thought.
    Dave.
  7. drptop70ss
    drptop70ss
    from NY
    Blocked right front brake hose will cause the pull to the left.
  8. You need to "arc" the brake shoes on both front wheels....there is a machine built by Aamco that will do this often overlooked proceedure on drum brakes...it literally grinds the friction material off of each brake shoe to precisely match them to the curve of the drum.....when the shoes are installed without doing this, there is not 100% contact between the shoe and the drum....one shoe may have 60% contact and the opposite shoe may have 85% contact...not an ideal situation...arcing the shoes guarantees 100% shoe/drum contact immediately.....sure, if you drive 30,000 miles the shoes will wear themselves in to a 100% contact pattern....but you need that now....ask around the old brake shops or old time mechanics...they will know exactly what you mean....hope this shines some light on your drum brake issues.
  9. flypa38
    flypa38
    Had a similar issue on my 56 Pontiac. Turned out to be the RIGHT front wheel cylinder. The thing looked like it was packed with mud after being rebuilt only two years prior. A new kit on that wheel cylinder and system flush solved it for me. Sure came as a surprise! Applied brakes at a traffic light and almost hit the concrete median! Mine only did it about a quarter of the time and never knew when it would happen. Good luck!
    Johnny
  10. bobwop
    bobwop
    from Arley, AL
    thanks for the suggestions and for sharing your experiences
