Technical brake help
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Mar 25, 2014.
  1. 29moonshine
    29moonshine
    i have a 34 with disc front and rear with a 7" single booster. brakes work fine. but when i press the pedal the motor reves up about 900 rpm. can not find any leaks any where.
  2. unkledaddy
    unkledaddy
    You could have a vacuum leak in the booster, or your idle mixture isn't adjusted properly.
  3. When stepping on the powered brakes changes the running characteristics it's a pretty safe bet to say that there's something wrong with the booster.
    Disconnect it, plug it, and run the car to verify
