Technical Brake hose routing
Discussion in 'The Hokey Ass Message Board' started by 4211papas34, Jun 28, 2025.
  1. 4211papas34
    4211papas34
    from chicago
    Installing brakes up front and it's time for me to run the brake hoses the current position they're in allows full suspension travel with no binding or rubbing additionally I jacked the front of and check the suspension travel with the tires off the ground so again there's no rubbing on binding however aesthetically I was hoping to do something a little cleaner any pictures or suggestions is appreciated thank you
  2. Jkmar73
    Jkmar73
    from Tulare, CA
    I used thru frame on mine.
    deucemac and lo c dan like this.
  3. RMR&C
    RMR&C
    from NW Montana
    I attach the mounting tab under the frame so you don't see it
    MMM1693 likes this.
