Brake ID help please
Discussion in 'The Hokey Ass Message Board' started by raidmagic, Jan 16, 2011.
  1. raidmagic
    raidmagic
    Hey guys, I know these are Ford but I don't know Ford what? I need to get two drums, wheel cylinders and shoes but I don't know what they came off of so I can't track down these parts. Any help you can offer would be great. If you know anyone with good used drums I'd be interested.
    Thanks
  2. if they are 11" then they are f1
    if they are 12" they are lincoln
    but from looking at the drum i say f1
    tk
  3. Master of None
    Master of None
    Looks like an 60's econoline spindle.
  4. squirrel
    self adjusters = 60s or later. Is it a 4.5" wheel bolt pattern?
  5. raidmagic
    raidmagic
    Yes they are. So what do I ask for at the parts house? 1970 F-1 brake parts?
  6. raidmagic
    raidmagic
    Measured from where?
    On the inside (friction surface) they are 10" from the outside to outside they are 11 3/4"
  7. squirrel
    Full size ford trucks had the 5.5" bolt pattern. I'm thinking the mid 60s econoline guess is probably right.
    also Mopars from the 60s had similar looking brakes, and 4.5" bolt pattern, but I don't think the spindles were the same?
    Any part numbers on it anywhere? yeah you have to clean it off to find them. If it's a ford you might see something like C5Ux-****-x
  8. Master of None
    Master of None
    I'd pull the wheel cylinder and brake shoes off and take them with you. Or you could make a spacer and get Gm mid size like 75 malibu front disk rotors and run disk breaks. You will have to make the caliper mount, but it works great.
  9. Master of None
    Master of None
    Looking at the picture a little more I think you may have a early Total cost axle from a t-bucket kit. They used 60's era econoline type spindles and breaks.
  10. raidmagic
    raidmagic
    Yes that is what this axle and brakes are from, so 60's econoline is what I'm looking for? thanks I'll hit the cl***ifieds for some drums.
  11. Often there is a part number and Ford Logo stamped on the backing plate. I'd say Econoline also, as they look like 1960's Ford brakes ( similar to Falcon/Mustang/Fairlane etc)
  12. raidmagic
    raidmagic
    Thanks for the tip, best I can make out is
    FF44443
    Wagner
    Does that look like a legit part number?
    Where would be a good place to look that up?
    Sorry for all the dumb questions
  13. squirrel
  14. raidmagic
    raidmagic
