Technical Brake id
Discussion in 'The Hokey Ass Message Board' started by Huckster59, Dec 14, 2024.
  1. Huckster59
    Huckster59
    image.jpg Anybody recognize This is on front of 57 with a set of two piece rotors. There’s thread inside.
  2. Happydaze
    Happydaze
    Haven't we already done this??
    Chris
  3. Huckster59
    Huckster59
    What kind of caliper will go on these since they have the threads in mounts?
  4. Huckster59
    Huckster59
    I don’t understand the threads. The bolts usually come from inside out. Got me lost.
  5. Happydaze
    Happydaze
    The 'bolts' are really pins with a thread just under the head. Regular gm stuff.
    Not exactly the same but watch this from about 12 minutes and you'll see what you want to know.
    Chris
  6. lostone
    lostone
    from kansas
    G.m. either early or metric caliper....
    Just have to pull measurements to see which one....
  7. Mr48chev
    Pretty much a standard issue caliper bracket for a GM caliper that is used on an early spindle.
    The caliper slips down over the rotor and the bolt and pin as it is called goes through that hole and through the caliper Through the bracket and through the other side of the caliper and the threads screw into the threads on the bracket with the bushing being clamped tight to the bracket for the caliper to slide on. This is how single piston GM calipers work. Chev caliper bolts.jpg Screenshot (1744).png
  8. Huckster59
    Huckster59
    Damn I had a brain fart. Caliper mounts on other side of plate.
  9. Huckster59
    Huckster59
    Hadn’t worked on early ones in a bit. Retired ATT fleet mech lol. Lotta new stuff. Thanks. Got it
