Brake ideas anyone?
Discussion in 'The Hokey Ass Message Board' started by Gerdy36, Jan 27, 2012.
  1. Gerdy36
    Gerdy36
    from Iowa
    I'm thinking about using a set of racing pedals from wilwood. The ones with the balance bar and two master cylinders so i could adjust the brake bias. Front separate from the rear ( example turning to the front for burn outs :D cool!!) But dont know what size of bore to use. They come in 1", 7/8", 3/4" bore. I'm running stock s-10 front disc brakes and stock s-10 rear disc brakes. I'm going with the setup inside the cab to clean up the firewall. The original place was under the floor, but that's not going to work because of the exhaust pipe and clearence issues with the ground. Plus there is plenty of room under the dash for this setup. Also if I put the master cylinders above the disc brakes they should bleed easier?? Any info or ideas are helpful. Thanks Chris
    Oh yeah this is on my 1949 F-3 ford truck that I'm building. It's stubbed with an S-10 front and rear sections. Which makes my ride height like 6" at the trans. mount. I'm 5'11" and can look across the top of the truck, thats without it being chopped. Looking forward to see some of the ideas or suggestions. Thanks Chris
  2. scrap metal 48
    scrap metal 48
    Sounds cool.. I'm happy if I can just stop.. Good luck........
  3. dave lewis
    dave lewis
    from Nampa ID
    1 inch front and rear...
    Dave
  4. lexington
    lexington
    I have used this setup on a 32 coupe works pretty well. They are hard to bleed manually because the cross rod keeps articulating until you get pressure built in both m/cs
  5. Gerdy36
    Gerdy36
    from Iowa
    Thanks, I'll keep that in mind when I go to bleed this setup.
    Chris
  6. Dane
    Dane
    from Soquel, CA
    For manual (no booster) 4 wheel disc brakes I use a 7/8" bore MC with a 5 to 6 to one pedal ratio. I would not go over 1" on a manual set up without at least a 6 to 1 pedal ratio. I like the Wilwood MC in the 7/8" size, but having the balance bar in a dual set up is best if you have the room.
  7. Gerdy36
    Gerdy36
    from Iowa
    Hey, thanks for the input. I didn't even think about pedal ratio. I have more than enough room under my dash to use this setup. Thanks again Chris
  8. seb fontana
    seb fontana
    from ct
    If you get the Wilwood pedals you can get in a 5:1 or 6.25:1 ratio..Since it ends up being that with the balance bar you are pushing on two cylinders at once I would try the 7/8 bore ones with the 6.25 ratio pedal set..I don't know if you can get enough differental in the balance bar for your burn outs, might need a shut off valve..
  9. fleetside66
    fleetside66
    Yes, I'd agree with the 7/8" bore. I chose a 1", but it doesn't stop quite the way it should. For example, I can't lock-up the brakes (with a light hot rod, that may be a good thing). I have a su****ion that I should have chosen the 7/8." And yes, the bleeding is tricky.
  10. Gerdy36
    Gerdy36
    from Iowa
    Thanks guys. All this info helps me out. Hate to buy something, then look back and wish why did I do it that way!!! But isn't that part of the fun.
