Projects Brake issue
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Feb 28, 2025.
  1. IowaTom
    IowaTom
    Guys - I have a '63 Studebaker Lark that I 'upgraded' to front discs (rear drum internals rebuilt) and a dual Raybestos MC36237, as suggested by the disc conversion company. Was having an awful time trying to bleed the system, so I switched to a Dorman M97934 master and added a 2-lb check valve for the calipers. This is a firewall mounted M/C, by the way.
    That gave me a pedal, but it's not reliable. Took the car around the block and had to pump the brake to get stopped. I have done dozens of brakes on lots of cars in my 72 years, including disc conversions, successfully. This has me stumped.
    I bought a proportioning valve, hoping if I add it to the system - with or without the #2 check valve, I might get a firm brake. I know I'm grasping at straws, at this point and need your input. Can I use both of these? My thought is to use the check valve immediately out of the M/C, going into the br*** valve's front brake in port. Overkill? Thanks so much in advance, and I'll save you the keystrokes; I'm a *****! :)
    Sharpone likes this.
  2. Kerrynzl
    Kerrynzl
    Let me guess? GM style Callipers?
    you shouldn't need any check valve for a firewall mounted M/C
  3. RICH B
    RICH B
    GM metric quick take-up calipers?
    David Gersic and Johnny Gee like this.
  4. Kerrynzl
    Kerrynzl
    That's what I am guessing! [aka Low drag callipers]
    These brake conversion kits usually have these ,and the vendors stick their head in the sand [being just a component supplier]
    A mid 80's S10 stepped bore M/C is an easy remedy [or swapping out the callipers]
    bobss396 likes this.
  5. That's the Jeep master, is it a Turners kit?. I have one on my girls '60 Lark wagon. It has a lower then drum pedal but firm, with a under the floor master and a manual prop valve. No need for res valves when the master is higher then the calipers.
  6. RICH B
    RICH B
    Unless the rear brakes need one.
    seb fontana likes this.
  7. All drums need them, either in the master or inline. That brings up a good point, make sure there's a 10lb res valve to the rear or the new master has one inside for the rear. I'm ***uming the rear brakes are stock Studebaker.
  8. BJR
    BJR
    You need a 10lb reserve pressure valve for the rear drum brakes, if it is not in the master cylinder. Also make sure the drum brakes are adjusted correctly.
  9. IowaTom
    IowaTom
    It is a Turner kit: https://turnerbrake.com/collections/car-kits
    He recently changed from a GM setup to a Chrysler caliper and it's been a pain from the get go.
    With my firewall M/C his instructions don't say anything about a rear check valve - but I'll try it!
    Might also try the S10 stepped bore before I give up and go back to drums all 'round.
    Many thanks for the tips, Fellers!
  10. IowaTom
    IowaTom
    Would this be a stepped bore type?
  11. bobss396
    bobss396
    Double down on the rear shoe adjustment. I'll make them a tad tight to get the bleeding done, then back them off to normal.
    Look for wasted-motion in the pedal link to the master, there should be no slop.
  12. hepme
    hepme
    just a thought, have you tried a long gravity bleed for the entire system?
  13. Check the master with a paperclip into the tube seat, very gently push inside the hole. If you feel a little spring back then it has a residual valve in it. If it doesn't you need one inline (red 10lb to the rear) and I recommend SSBC valves, the ones in your picture tend to leak.
    So do you have the new Chrysler caliper or the GM (S10 4x4 if I remember correctly)?.
    RICH B and alanp561 like this.
  14. Last edited: Mar 2, 2025
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Remember that thread very well.
