57 Chevy with power disc front brakes. Brakes are marginal at best. Booster is good, new m/c. I am wondering if since this was not power break car originally if the throw of the brake pedal is wrong. Can this be corrected with a different m/c, or do I need to drill a hole in pedal arm, and if so where? Thanks
Let's see a picture of your pedal arm with the rod that goes to it. Maybe we can see if the geometry is wrong
If you put power****ist brakes on a non power brake car it will USUALLY have very easy or low foot pressure if you kept the MC cylinder diameter the same. Non power brake ratio is 6-1 or more and power 5-1 or less.
Manual brakes have a higher pedal ratio than power brakes. This can lead to a "too easy" pedal, allowing for easier lockup if you aren't accustomed. Not the other way around.
