brake light switch question
Discussion in 'The Hokey Ass Message Board' started by THE CHIEF, Nov 3, 2008.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
    currently im running a GM under the dash swing pedal set up in my pontiac and it had the brake light switch mounted on it, i just purchased a new set up since the im not to happy with whats on there now, my problem is that the new one dosent have a mount for the brake light switch, i have dont have much experience wit brakes, wat are my options
    here is the pedal ***embly i have now
    and this is wat i just purchase
    and this is wat the brake light switch looks like
  2. you could put a hydraulic switch in the brake lines , or male a bracket to use a mechanical one
  3. THE CHIEF
    THE CHIEF
    from MIAMI
  4. kisam
    kisam
    Why couldn't you fab up a mounting plate similar to the old one and weld/bolt it on the end of the gold bracket. Your fab work would not have to be exact, only that when the pedal at rest, the switch is pushed in and when the pedal is engaged the switch is out. And you can adjust the switch in or out as needed.
  5. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    If you're replacing the Master Cylinder that means you'll be replacing some of the lines and rebleeding the brakes. Just put a "T" in the line and use a pressure switch. That'll be the easiest solution.
  6. phat rat
    phat rat
    If you have any fabricating skills making a bracket to use the switch you've been using is the most reliable. Just check here on the board how often guys have problems with the hydraulic switches
  7. woodscavenger
    woodscavenger
    from idaho
    Do the pressure switches turn the lights on when the ****on is released?
  8. Flipper
    Flipper
    from Kentucky
    Somebody on here gave me direction on the way I did mine. I used the GM switch and mounted up high on the backside of the pedal. There is an arm welded on the backside of the pedal that works the switch. Yours could be a lot prettier than mine turned out, but mine is out of plain sight in the truck.
