1952-59 Ford Brake light switch
Discussion in 'Off Topic Hot Rods & Customs' started by tcoupekyle, Jun 23, 2025.
  1. tcoupekyle
    tcoupekyle
    Anybody have any great ideas for a brake light switch. I have one of those speedway switches with the little lever and it’s constantly giving me issues.
  2. GAmes
    GAmes
    Do you have a port in the brake lines that will accept a pressure switch like those on a '54?
  3. Fairlane 62
    Fairlane 62
    As GAmes mentioned you can plumb in a pressure actuated switch like what was used on many cars in the 50s and early 60s. Or you can use a plunger type switch that is activated mechanically by the brake pedal. I have found them to be more reliable than the lever type.
    JeffB2 likes this.
  4. Texas57
    Texas57
    I use both of the ones mentioned because my computer needed one. I have had no trouble with either. My pressure switch comes off one of the master cylinder ports if I remember correctly.
  5. Paul2748
    Paul2748
    If you are interested in a mechanical switch that mounts on the interior dash cross brace I have pic and a write up that I made for my 54. Message me with your email and I will send the info to you.
  6. T Hudson
    T Hudson
    I'd be interested to see that. Might be able make it work on my '55. Could be a good one for the stickies.
  7. bobss396
    bobss396
    I converted my '64 Ford to a mechanical switch around 1977. I had to fab up a small piece using angle iron as the stop and drill a hole for the stop and one for the switch.
    IIRC, I used a '66-ish Mustang switch. My '59, I left enough slack in the pressure switch wires in case I wanted to go mechanical at some point.
    JeffB2 likes this.
  8. evintho
    evintho
    Here's how I mounted a generic switch on my '54. One tab welded to the pedal ***embly mount, to mount the switch and one tab welded to the pedal itself to operate the switch.
    bobss396, down-the-road and dodg66440 like this.
  9. Paul2748
    Paul2748
    Here is a few pics on what I did for my 54
    Kustomline54 likes this.
  10. Paul2748
    Paul2748
    Here is some pics of my conversion (54). I have a write up if any one is interested
      725.4 KB
      772.1 KB
      1.2 MB
      111.8 KB
      712.1 KB
  11. Dos Cincos
    Dos Cincos
    My bracket is much less elaborate than the others but works well. Just a piece of angle iron with a hole drilled through it and welded in place.
    dodg66440 and JeffB2 like this.
  12. tcoupekyle
    tcoupekyle
    Where the switch come from?
  13. Dos Cincos
    Dos Cincos
    I've recorded just about every part I've put on the car but this one apparently. Pretty sure it came from a parts store like Autozone/Advance/Napa and isn't anything special. Just a 12v mechanical brake switch like the others have posted
  14. GAmes
    GAmes
    I believe that a self adjusting one, like the one in my '97 Dodge pickup, will work in that application.
  15. evintho
    evintho
    Dos Cincos likes this.
  16. JeffB2
    JeffB2
    from Phoenix,AZ
    evintho likes this.
  17. evintho
    evintho
    When I bought mine 2 years ago it was like $6. Gotta luv inflation!
  18. JeffB2
    JeffB2
    from Phoenix,AZ
    I guess the Inflation Reduction Act was only good in name only ? :rolleyes: :(
  19. ottersea
    ottersea
    Good for the croanies that got the moey
  20. tcoupekyle
    tcoupekyle
    lol I deal with that dang act all the time
