Technical Brake line/exhaust proximity
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Cowboy, Sep 27, 2016.
  1. Hot Rod Cowboy
    Hot Rod Cowboy
    Been spending some time under my new '54 Chevy wagon. While under there, I noticed that the brake lines are only 1.25" or so from the exhaust (see pics). This doesn't seem like a good idea to me, but I'm no where near an expert. Eventually it'll all get redone because I'll be switching to a firewall mount m/c from Walton fab, but I was hoping to drive it as is for awhile before tearing into anything. Is this safe or is this a fix it quickly situation?
  2. seb fontana
    seb fontana
    from ct
    Looks like you have enough extre line, move up as much as possible and put a heat sheild.
  3. low budget
    low budget
    from Central Ky
    Not sure but it doesnt look like it would be that big of a deal to move them on top of the cross member or at least take the little bracket bolts out and put the line above the bolt with same bracket and same hole, but moving them on top of the X member may be better, running them across the body above the trans would probably be even better yet.
  4. bobss396
    bobss396
    I had a brake line very close to the header on my '65 Chevy C30. The brake line became porous after it turned cherry red.
  5. crminal
    crminal
    X2
    Even another inch away would make a big difference.
    Or a simple sheet metal shield clamped to the pipe would help for now.
  6. That's not as close as I was expecting. Why not just give it a little extra bend away? Wouldn't give it a second thought.
  7. 50dodge4x4
    50dodge4x4
    If I can get my finger between the brake line and the exhaust, it will be good. That is enough room for air to flow past to cool the line.
    However, if you don't think its enough, you have to move it before you will feel comfortable about it, and it will always be on your mind. It will ruin your driving experience. Gene
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    1 more inch and it's good for ever. Don't do the firewall master ****. They look like **** under the hood.
    hotdamn likes this.
  9. 911 steve
    911 steve
    from nebraska
    I have a 40 Ford sedan with the master cyl & booster under the floor. its close to exhaust. I have noticed after a long road trip (200-300 miles) I seem to have brake fade, such as coming to a stop on an interstate exit ramp. is it possible that's related to the proximity of the cyl to the exhaust??
  10. Rusty O'Toole
    Rusty O'Toole
    Way too close for safety. The exhaust looks too close to the frame as well. Yes, hot brake lines can cause brake fade. If the fluid boils you could lose your brakes completely.
  11. bjinx
    bjinx
    Will be dealing with M/C, brake lines and exhaust on my sedan. So it sounds like the consciences is 2 1/4 " - 2 1/2" of space between brake line and exhaust is acceptable, but more would be better if there is room.
  12. There is a heat sheilding material the go-fast boys wrap around their turbochargers. It's fairly thin, can be worked like 0.8mm Alluminum, and cheap.
  13. phat rat
    phat rat
