Brake line flush question
Discussion in 'The Hokey Ass Message Board' started by Hop-up, Jan 28, 2007.
  1. Hop-up
    Hop-up
    OK so my lines are actualy in fine shape, theyre not ruted opr anything. But i disconnected one of them to check for sludge, and there is some. So is it possible tp purge the lines of all the sludge in there? I dont there theres an incredivle amount. Could i fill up my MC and then disconnnect the lines from the wheel cylinders and then pump the pedal? Or is all of this impossible?
  2. rodknocker
    rodknocker
    crack all of your bleeders on all 4 wheels and let gravity take hold, just be there to keep filling the resivoir,unless you want to take your whole system apart and clean everything individually
  3. Hop-up
    Hop-up
    well the MC is out right now, about to go back in. But will gravity clear the sludge?
  4. rodknocker
    rodknocker
    ya know what i take that back,bleed each wheel individually using your pedal
  5. yorgatron
    yorgatron
    go to the store and buy a quart of rubbing acohol and run it through there.
    then flush it with fresh brake fluid.
    if there's a lot of crud coming out you really should dismantle your M/C and wheel cylinders and clean them out also.
  6. Hop-up
    Hop-up
    ill do the wheel cylinders, but the MC is brand new. OK thanks guys.
  7. 47bob
    47bob
    I just flushed mine and used denatured alcohol from Lowe's. Disconnect all the lines and flush them good. I used a pump type oiling can and that worked good. Rebuild the cylinders if needed and you'll have a good system. .....Bob
  8.
