Brake line question
Discussion in 'The Hokey Ass Message Board' started by Hot Rod Willys, Jan 16, 2010.
  1. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    Getting ready to run all new brake lines on a new build, question.........if the rear brakes are drum and the front are disc do I do the rear lines in 1/4 inch and the front in 3/16 or do them all in 3/16?
  2. artiep
    artiep
    The size of your brake lines effects pedal pressure, I would make them all 3/16.
  3. 1/2done
    1/2done
    from Ohio
    I did all mine in 3/16 and the brakes worked great.
  4. Hot Rod Willys
    Hot Rod Willys
    from Ohio
    I am assuming you guys are running disc/drums correct? It seems to me that the factory did 1/4 for drums and 3/16 for disc, thats the reason I am asking. Thanks for the repies..........:)
  5. milwscruffy
    milwscruffy
    Done them both ways and all worked out fine. Pedal pressure is more on the bore size on the master than brake line size. Chevrolet used the 1/4" - 3/16" combo for many years. Good Luck and get to flaring.
  6. 29nash
    29nash
    from colorado
    It doesn't matter as far as operation goes. Line could be 1/2 inch wouldn't change volume/flow/pressure, which are related to piston sizes of MC & slave. Larger line can make it more difficult to bleed out air bubbles trapped in high points of the plumbing.
  7. LowA100
    LowA100
    Dave
    It really doesnt matter. Once the brakes are bled, your pedal pressure is directly related to the master cyl bore etc. and you are just pushing pressure
    marsh
  8. Crusty Nut
    Crusty Nut
    no it doesn't. Bore size and pedal ratio determines pedal feel.
    Just run all 3/16". It's easy to bend and route.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    3/16 here also, thats what i ran
  10. pan-dragger
    pan-dragger
    I always use 3/16".
