Customs Brake Line Routing/protection
Discussion in 'The Hokey Ass Message Board' started by FAKKY, Jul 7, 2019.
  1. FAKKY
    FAKKY
    What do people think about routing brake line here.
    I can't run it through the C-channel frame as its fully boxed (closed on inside with supports). Going lower is hard to to the cross member and mainly Control arm supports.
    The line does rest on the top of the engine supports as it crosses behind the CA - which makes me wonder should I add ....
    https://www.amazon.com/Stainless-Brake-Protector-Gravel-Spring/dp/B01IRQXDZC
    thoughts ?
  2. DDDenny
    Short section of rubber hose.
  3. FAKKY
    FAKKY
  4. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Just an insulated clamp...... Tapped into the frame. If your worried about vibrations, once secured, it ain't going anywhere. If you want to hide it, just it bend down, and run it under the frame rail.... The further away from heat=the better.
  5. FAKKY
    FAKKY
    thanks.
    Is heat a real concern ? I measured the clostest distance at the collector of exhaust at around 1.6". Everything else closer to 3".
  6. 325w
    325w
    Would avoid running under the frame. Some tire store kid might throw a jack right under the brake line and mash it.
    kbgreen, Black_Sheep and INVISIBLEKID like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    I wouln't worry about the heat, as long as it not touching the exhaust your OK. HRP
  8. FAKKY
    FAKKY
    Thanks all. Good tips.
  9. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    True..... BUT- That's if you let a monkey touch things....... Who takes there ride to a "tire store"? :confused:
  10. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Yes- Heat is a concern with brake lines........ Further, the better. Also- cosmetics.
  11. David Gersic
    David Gersic
    from DeKalb, IL
    You might need a heat shield by the exhaust tube.
    Adel clamps on the brake line to secure it will prevent rubbing.
    The stainless spring armor is awesome. Saved my *** on Power Tour when an exhaust hanger broke and dropped the pipe on the rear axle. I had armored the brake tubing on the axle, since I had the stuff left over from doing the same on the rear axle of my DD. The exhaust tube bounced on the armor, kinda bent it up a bit, but didn’t manage to squish the brake tubing.
    gimpyshotrods likes this.
  12. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^^^ Do as he say's^^^^^^^^^^^^^^^^^^^^^^^^^^
  13. gimpyshotrods
    gimpyshotrods
    All that, yo!
  14. ekimneirbo
    ekimneirbo
    I like these kind of clamps. They are inexpensive and secure the lines tightly to the frame. They are made of some kind of fiber or plastic but are very strong...and they come in different sizes for exact fit to the line. Look good when done too. Clamp x.jpg
  15. LM14
    LM14
    from Iowa
    Al my brake and fuel lines are surface mounted. I've got Billet Specialties aluminum clamps. 2 piece aluminum clamp, the 2 pieces interlock to keep them oriented correctly and they attach to the frame rail with a single tapped hole. The bolt is recessed so nothing is sticking out to grab you. If you go to anywhere that sells them, they ill also have a chart on spacing of clamps so you don't have too long of a section unsupported. Very clean and simple to use. Might have to squint to see them but these pictures will show them used in a couple different sizes.
    SPark
  16. Bandit Billy
    Bandit Billy
    Gravel guard.
    alanp561 likes this.
