Brake Line Size????
Discussion in 'The Hokey Ass Message Board' started by 54barnfind, Mar 13, 2012.
  1. 54barnfind
    54barnfind
    from Indy
    Have a 54 chevy truck with drums all around, didnt like the idea of a single line master cylinder so I put a dual line with a booster from a 05 Monte Carlo on it. Now that the new lines are on and the sytem is bleed the shoes are not moving much-shoes are on with new cylinders, drums are off- Any clues as to the problem-Thought that the brake line size may have to be bigger, hope not though....thanks
  2. Willy301
    Willy301
    Line size makes NO difference, it is merely to carry fluid. The MC pushes a certain amount of fluid out and the same amount of fluid enters the wheel cylinders. If the shoes aren't moving, I think you still have some air, or you push rod from the pedal to the MC needs some adjusting.
  3. Vintage_Iron
    Vintage_Iron
    from Maryland
    If line size made NO difference why would 3/16 line give you a pressure increase over 1/4 inch line? Same amount of fluid pushed through a smaller opening, restriction = pressure increase.
  4. ryno
    ryno
    You need to check bore size, also your 05 Monte master is more then likely build with disk brake residual valves. Meaning they will push 2 lbs of pressure, when your drums require 10 lbs.
    3/16 should be fine.
  5. Da Tinman
    Da Tinman
    you need a m/c from a drum drum system,,,, 70 montecarlo drum drum would probably suit you better.
  6. Steves32
    Steves32
    from So Cal
    It will give you a volume increase- not a pressure increase.
  7. belle
    belle
    3/16 is just fine
    you have other issues
  8. 32ratsass
    32ratsass
    Residual valves have nothing to do with the pressure supplied to the brakes. They maintain the specified amount of residual pressure at the wheels when the brake is released, to keep the fluid from all returning to the master cylinder and letting the pads move too far away from the rotor. They are only needed when the master cylinder is mounted below the wheel cylinders as in an under floor mounting location. Firewall mount does not need residual valves.
  9. HellsHotRods
    HellsHotRods
    I agree
  10. gimpyshotrods
    gimpyshotrods
    The ONLY things that increase the pressure in a braking system are:
    Force applied at pedal.
    Force applied by boost ***ist.
    Higher pedal ratio.
    Smaller master cylinder bore size.
  11. You need to check that the master is getting a full stroke. If it is, and you are still not getting enough travel at the shoes than you will have to check the bore size. It needs to be pretty close to the OE master.
  12. bobss396
    bobss396
    Better yet, I always try to get the donor part as close to matching the vehicle its going into. In a '54 truck, I'd be looking at a '67 or so Chevy C10 master. Truck brakes are balanced differently than a p***enger car.
    Bob
  13. OldBuzzard
    OldBuzzard
    This is what you want to listen to.
    Some may think that line size makes no difference. But, line size, master cylinder & wheel cylinders are DESIGNED to work as a SYSTEM.
  14. brokenspoke
    brokenspoke
    Put the drums on before bleeding
  15. 40FordGuy
    40FordGuy
    Are you using a non power m/cyl ? Those have a deeper pushrod hole, giving the same effect as a "too short" pushrod....Power m/cyl have a shallow pushrod hole....because there is a "guide" at the booster....
    From experience...... 4TTRUK
  16. V8 Bob
    V8 Bob
    Just the opposite on all I've ever worked on or seen. Generally, power masters have to have a deep push rod bore because the booster push rod cannot be retained, like in manual masters. There may be some boosters that have guided push rods, but that's not the norm.
    However, it's good advice to be sure the master you use has a deep bore when used on a custom manual system. You don't want the push rod to be able to fall out of the bore. :)
  17. srs1
    srs1
    are you using the stock pedal? you need to measure the stroke (or movement) of the rod. i have had to lengthen the little tab on the pedal that the clevis hooks to, to get more stroke. it would be a good place to start.
  18. 54barnfind
    54barnfind
    from Indy
    srs1 - you hit the nail on da head - didnt have a long enough stroke
  19. gimpyshotrods
    gimpyshotrods
    Don't feel bad, dude. It is a common problem.:D
