brake line
Discussion in 'The Hokey Ass Message Board' started by mcmopar, Jan 27, 2013.
  1. mcmopar
    mcmopar
    from Strum, wi
    I bought some 1/4" ss coil tubing for another project, but it's not going to work for it. Can I use it for my brake lines or is it to big? Should I get 3/16", or is there a better size?
  2. kirby1374
    kirby1374
    I just used 1/4 for my 40-48 ford brakes. I believe that is the size used on 40-48 fords new.
  3. tb33anda3rd
    tb33anda3rd
    won't matter which size. how are you going to flare it?
  4. mcmopar
    mcmopar
    from Strum, wi
    I am not sure how to flare it, I ***umed it would be the same as any other flare, except with different angle for ss lines.
  5. tb33anda3rd
    tb33anda3rd
    i was never able to double flare ss line, it always split.
  6. mcmopar
    mcmopar
    from Strum, wi
    I have seen some info on them and ss has a different flare so they don't split, if i read them corectly. I am also using 304 aneled ss.
  7. NoLifeTilLeather
    NoLifeTilLeather
