Technical Brake lines
Discussion in 'The Hokey Ass Message Board' started by sdluck, Jun 19, 2019.
  1. sdluck
    sdluck
    I am making new brake lines for my Hot Rod out of 3/16 brake lines with IF fittings.Do you guys have any good way to test them other than plugging them and charging them with compressed air?
  2. Bandit Billy
    Bandit Billy
    I used brake fluid. Seriously, I built the entire system on the 34 out of stainless, installed it, filled the M/C and bled it out with a vacuum bleeder...not a drip, works great.
    My advice is if you haven't done a lot of flaring, find someone who has and learn everything you can. Buy a better flaring tool than you think you need. Don't be in a hurry. Oh yeah, don't get polishing compound in the tubes while they're on the buffer ( I used rubber vacuum caps). :cool:
    egads, olscrounger and lothiandon1940 like this.
  3. One thing I've learned over the years. When making final clamp of your flair in the vice, do not over compress it. Let that happen on final tighten up with fittings in place. The final squeeze in place makes the seal. Oh, and use a hand held pin ream to clean the inside of the flair of any overlap material. You'll be fine.
  4. Truck64
    Truck64
    from Ioway
    Put the fitting on the line before flaring.
  5. DDDenny
    SD already knows this but for those of the anxious predisposition, don't forget to put the fittings on before you bend and flare the lines:mad:.
    Damn, I hate it when that happens.
    I sure like the brake lines from NAPA, Autozone, etc that have the fittings already installed, they have a black/green coating so they dont stand out too brightly and they are easily bent by hand.
    With careful layout, a few junction blocks (straights and 90's) and knowledge of available lengths, a nice job is achievable, I've done both my roadster and my 67 Nova this way.
    If I remember correctly, the section lengths come in increments of 10" versus by the full foot, such as 20, 30, 40, 60 inches long.
    olscrounger likes this.
  6. DDDenny
    Note to self: type faster, see above^^^^^.
  7. lothiandon1940
    lothiandon1940
    ..........Excellent advice! Don't ask me how I know.:(
  8. Bandit Billy
    Bandit Billy
    All joking aside, I take brakes very seriously. Like you were working for NASA or Boeing...ok NASA, make every thing perfect, no "that's close enough". Drink after you are done and not during (this will also aid in not flaring the ends without the fittings in place).
    mgtstumpy, egads and lothiandon1940 like this.
  9. V8 Bob
    V8 Bob
    You want to pressure test only with brake fluid. Bleed the system until you have some pedal, then use isopropyl or denatured alcohol to clean all fittings and connections. (The alcohol does a great job of cleaning the connections and any spilled brake fluid) Next, apply about 150-200 lbs pedal effort for 10 seconds or so and check for any leaks or weeps, if the pedal holds steady. When you are sure the system is tight, continue final bleeding, and a final high pressure check.
  10. RICH B
    RICH B
    That green coating is fine on my rusty old DD truck; but doesn't belong on a hot rod.
  11. Russco
    Russco
    from Central IL
    Check out NiCopp line. It bends and flares much easier.
    Chavezk21 and egads like this.
  12. You may also want to tape the fittings onto the tube. Otherwise, they slide around and interfere with your work. Actually, I flare one end then use masking tape to hold the fittings while I complete the flaring job. A careful clean-up is in order.
  13. I like the ones at Napa. Different lengths, inexpensive, and the flaring is done. It sure saves a lot of headaches.
  14. uncle buck
    uncle buck
    The difference between them
    ClayMart likes this.
