Technical brake lines
Discussion in 'Traditional Customs' started by gdrummer, Oct 20, 2023.
  1. Happydaze
    Happydaze
    And don't bend without first checking the tube nut is in the correct position.
    Chris
    Tman, nochop, 1971BB427 and 1 other person like this.
  2. bobss396
    bobss396
  3. gdrummer
    gdrummer
    wow, so much info! thanks for all the replies. so if i'm understanding, the adapters for the proportioning value and the brake light switch are different fittings with different threads and those need to be sealed? i'm able to get rid of the brake light switch but is there a brake fitting adapter with the correct thread, that i can use on the proportioning valve? and if those adapters used to connect it are wrong, why are they included with the valve?
    thanks for all the helpful info and i will post any updates!
  4. nochop
    nochop
    from norcal
    If they were included with the proportion valve they are probably correct. Do a little research on different types of threads it probably will help you along all throughout your builds. I am always checking the different charts that are available online.
  5. gdrummer
    gdrummer
    hey boss, where do those washers go?
  6. jimvette59
    jimvette59
    You need to educate yourself the difference between NPT ( pipe threads ) and tubing 7/16 x 24 threads per inch. ( TPI ).
  7. nobby
    nobby
    have you 'ever' used a turret styel brake flaring tool
    from the likes of sykes pickovant
  8. jimvette59
    jimvette59
    No
  9. Last edited: Oct 22, 2023
    zggum, Tow Truck Tom and nochop like this.
  10. gdrummer
    gdrummer
    hey ya'll just wanted to update and thanks for all the helpful replies. after redoing all the lines with the correct process and sealing the fittings that should be sealed, and switching to the pedal operated brake light switch i'm pleased to say, no leaking anywhere!
    thanks again for all the great info!
    cheers!
    zggum, 1971BB427, leon bee and 10 others like this.
  11. J. A. Miller
    J. A. Miller
    from Central NY
  12. tb33anda3rd
    tb33anda3rd
    I found on my trusty old [blue -point] flaring tool a similar problem and solved the issue by putting a few drops of oil on the tool threads and between the cone and the screw arbor . this allowed the cone to push the seat evenly.
    Algoma56 and TrialByError like this.
  13. nochop
    nochop
    from norcal
    A little dab will do ya
    tb33anda3rd and Algoma56 like this.
  14. Glad you got it fixed up. I'll often put the fitting on the line and tape it to the line to keep it in place, on he line until ready to bend line or install.
