Brake lube for Lockheed drum pivots?
Discussion in 'The Hokey Ass Message Board' started by Matt Dudley, Oct 6, 2025.
  1. Matt Dudley
    Matt Dudley
    from New York
    I don’t know where my old Plymouth manual went so I can’t check that at the moment. What lube can I use for the shoe pivot pins? Silicone brake grease acceptable?
  2. jimmy six
    jimmy six
    Lubriplate was the standard for all brake shoe to backing plate and pivots when I worked in the Sears auto center in the 60’s. I still use it today on any drum brake system and I have 3 vehicles with drum brakes.
    ClayMart likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the main board, the antiquated forum is for NON automotive 65 and older collectibles
    RodStRace likes this.
  4. Matt Dudley
    Matt Dudley
    from New York
    Sorry for putting it in the wrong spot. Didn’t think to put it in the main forum being the car itself is an unmodified original..
    I still do some drum brakes, especially parking brakes, but on that stuff I just use some of the caliper grease at the Contact points. Being this is a hinge essentially, the lubriplate would probably be ideal and I’ve forgotten all about the lubriplate being most of what I work on is modern these days.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    My go to is Permatex Anti Sieze Compound
    SS327 likes this.
  6. SS327
    SS327
    Lubriplate or if I feel like looking like the tin man Anti-Seize.
    Tow Truck Tom and Algoma56 like this.
  7. CSPIDY
    CSPIDY
    Plastilube #3, is impervious to heat and cold, very sticky and hard to wipe off.
    Great ***embly grease, can be used as a sealer as well
    Will not dry out over time
    I put that sheet on everything!
    Tow Truck Tom and winduptoy like this.
  8. squirrel
    I haven't bothered with adding grease to drum brake parts for decades, and strangely enough, the brakes still work and don't seem to wear out more, while I have them.
    RICH B, Tow Truck Tom and GuyW like this.
  9. Matt Dudley
    Matt Dudley
    from New York
    I actually have some plastilube
    CSPIDY and Tow Truck Tom like this.
  10. Matt Dudley
    Matt Dudley
    from New York
    I don’t all the time either, especially on my own stuff. But this is basically hung on a hinge, and it has a cup with felt to hold a grease behind it. They are anchored with a C clip
  11. squirrel
    perhaps a dab of normal ch***is grease?
    Tow Truck Tom likes this.
  12. Doublepumper
    Doublepumper
    from OR-WA, USA
    I just use wheel bearing grease. It stays in place, doesn't melt and migrate from where it's applied. Plus I have lots of it.
    57Fury440 and Tow Truck Tom like this.
  13. ClayMart
    ClayMart
    For drum brakes at least, Lubriplate has always seemed to be the "go to" as far back as I can remember. All the techs had a open can with a solder flux brush stuck in it on their work benches.
    Never heard of Plastilube before. Sounds interesting. Does it tend to be spendy?
    SS327 and Tow Truck Tom like this.
  14. '29 Gizmo
    '29 Gizmo
    from UK
    Brake grease is a very low pressure lubricant, no good for point loading. Anti-sieze grease is abrasive due to metalic content. Use any lithium based grease, preferably one with water displacement properties. I use the white lithium which is very sticky on brake mechanisms
  15. CSPIDY
    CSPIDY
    $7-$11.00 per tube
  16. ClayMart
    ClayMart
    Well that wouldn't exactly "brake" the bank, would it? :p
  17. Matt Dudley
    Matt Dudley
    from New York
    I’m not real sure where to get plastilube locally. The way I have some is through work, and I get packets of it in some stuff but I use jars of brake lube and grease that they give us. I don’t have a Lot of plastilube but I have enough to do what I need. I have about a drawer full of silicone brake grease packets, and some moly packets as well
