Technical brake master and booster
Discussion in 'Traditional Hot Rods' started by WP38, Mar 22, 2015.
  1. WP38
    WP38
    Looking to place a brake booster and master on my 48 Merc, I will be converting to disk on the front , Looking at speedway , they have a booster attached to the brake pedal I also am converting to automatic. Any other suggestions thanks
  2. I would start with the stock master that corresponds to whatever donor car your front calipers are coming from. If the donor was disc/drum then you should be all set to just replicate the brake plumbing of that vehicle in your '48.
