Technical Brake parts found but will it work?
Discussion in 'The Hokey Ass Message Board' started by shorrock, May 22, 2023.
  1. shorrock
    shorrock
    I am desperately needing T-joints for the front and rear brakes of my 34 Ford. I have 1/4" brake lines and need to join the wheel cylinders to the MC. I have searched Rockauto with all sorts of names and a couple OE numbers but to no avail. As I order everything else needed there it would be nice to just add two of these blocks to my next order. Finding this stuff in Europe or Germany is quite difficult.
    Thanks!
    Harty
  2. CSPIDY
    CSPIDY
    What style end flare do you have?
    Reverse or standard? 45 degrees?
    Maybe a picture would help
  3. milwscruffy
    milwscruffy
    upload_2023-5-22_8-53-10.png This is from Rockauto's website.
    Johnny Gee and 31Apickup like this.
  4. ekimneirbo
    ekimneirbo
    from Brooks Ky
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
  6. RICH B
    RICH B
    You look up the part numbers needed on Edelmann's web sight; then use the number to search on RockAuto's and other web sights to find your best source.
    Johnny Gee likes this.
  7. Last edited: May 22, 2023
  8. shorrock
    shorrock
    Thanks guys - I will order at Rockauto. I found everything that I might need to run the whole system with 45 degr inverted flare. I have recently converted the front end to around 1965 F100 drums (11" x 2"). The MC is 15/16" and the rear drums are Chevy S10 with 7/8" diameter. Front WC are 1 1/16" but will be replaced with 1 1/8" to get a bit more bite. Hopefully this will result in a dependable drum brake system that allows to run the car a bit quicker than before and still be able to stop in time.
    Thanks for all the help and suggestions!
    milwscruffy likes this.
  9. 325w
    325w
    Life with 3/16ths line is much simpler.
    bobss396, Beanscoot and alanp561 like this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    3/16” doesn’t fit so well on those year of brake hose’s. Do you suggest more fittings are in order to make it work?
  11. RICH B
    RICH B
    Unless you are running Lockheed brakes.
