brake pedal/master cyl
Discussion in 'The Hokey Ass Message Board' started by rer_239, Mar 3, 2012.
  1. rer_239
    rer_239
    working on a model a coupe with frame mounted pedal/cylinder and have some questions. how much pedal travel should i have? should the pedal be below the floor (to increase foot room)? it looks like i have to shorten the (adj.) operating rod that goes into the cylinder. to do that i'd have to remove it and cut an inch (or so) off and thread it. if i pull it out, will i lose the fluid?
      489.1 KB
      506.2 KB
  2. seb fontana
    seb fontana
    from ct
    The lever part of the pedal should come up to the toe board..You can shorten rod to make this happen..No you will not lose fluid..
  3. scrap metal 48
    scrap metal 48
    From your pics it looks like your pedal ***embly needs to be mounted more forward so the first bend will be under the toe board like seb said..... Lay your toe board in and you will see where it needs to go.....
  4. rer_239
    rer_239
    hey, thanks guys. very helpful and quick. you guys may not realize how much us newbes rely on this site. thanks again.
    rer_239
