Hot Rods Brake pedal ratio?
Discussion in 'The Hokey Ass Message Board' started by 550Coupe, May 29, 2020.
  1. 550Coupe
    550Coupe
    Was ordering a new front disc brake kit from Wilwood and when what type master cyl came up I was asked what was my brake pedal ratio, that it should be a 6:1 ratio. I really wasn't sure. I'm using an early Ford (1941) brake pedal ***embly. Does anybody know off hand or know where I can find this information? Thanks in advance for any help.
    Art
  2. pitman
    pitman
    6:1 works for me.
    Used on '60's hardware fitted into
    Early Fords
  3. 550Coupe
    550Coupe
    So are you saying my 41' ford pedal IS 6:1? That's what i need to know. Thanks
  4. pitman
    pitman
    Only that it is a Std. Ratio used often for non power brakes. Master & wheel cylinder bores play a role in your system.
  5. V8 Bob
    V8 Bob
    It's probably just over 6:1, but you could measure it to know for sure. ;)
  6. jimmy six
    jimmy six
    Wilwood asked me the same question. My non power brake car was 5-1. It still works great non power because they can control it with the diameter of the master cylinder. The smaller the M/C the less pressure your foot needs but the move it needs to travel. (Fluid dynamics). I put smaller rear wheel cylinders to help with this too. Personal opinion but power brake cans under the hood look like **** to me. I realize yours under the floor if you wanted one.
    550Coupe likes this.
  7. RICH B
    RICH B
    Here's a picture of a '40's pedal; little better than 6:1 ratio.
    dana barlow, pitman, 550Coupe and 2 others like this.
  8. 31Apickup
    31Apickup
    dana barlow likes this.
  9. 550Coupe
    550Coupe
    Thanks guys. That answers my question. Much appreciated!
    Art
