Technical Brake Pressure Switch?
Discussion in 'The Hokey Ass Message Board' started by sbf001, May 12, 2016.
  1. sbf001
    sbf001
    from New York
    Hello
    I converted from a single bowl master cylinder to a dual master cylinder, Is there a way I can use my stock pressure switch with the new master cylinder?
    Thanks
  2. mrspeedyt
    mrspeedyt
    put a 't' in one of the lines right by the master cylinder.
    but you would have the brake lights activate much sooner if you have a mechanical switch. you can adjust it so to have the brake lights come on with the slightest movement of the brake pedal. this is my plan to do to my 41 cad if it doesn't sell soon.
    Dino64 and tfeverfred like this.
  3. F&J
    F&J
    OEM cars that had dual master with pressure switch, had to have two pressure switches. That was FED requirement to have brake lights on each circuit.
    You are better off to run a mechanical switch
    Dino64 likes this.
  4. tfeverfred
    tfeverfred
    Pressure switches ****! But....... if you have to have one, you can do as above and mount it the line. But..... seriously..... they really do ****.
  5. bobss396
    bobss396
    I have one on the proportioning valve on my Ford, so far so good and I ran them for years. I've had more of the ones on the brake pedal go bad and only 1 hydraulic fail on all the '64 Fords I had.
  6. unkledaddy
    unkledaddy
    To keep texters from rear-ending you..
  7. andyg
    andyg
    When their head is consumed by the phone, it won't help you!
  8. sbf001
    sbf001
    from New York
    Looks like I will be going with the speedway mechanical switch. One question I have is when the lever is pushed in are the brake lights one or when pressure is let off the switch the lights come on?
    Thanks
  9. themoose
    themoose
    I used one from Ron Francis...Mounts behind the brake arm and is normally closed and opens when the plunger is pushed in when the retracted brake pedal arm or linkage hits it. Fully waterproof for under car external mounted if needed.
  10. sbf001
    sbf001
    from New York
    I have hanging pedals so when I press the pedal the switch should be open?
    Thanks
  11. themoose
    themoose
    The switch would be mounted on the back side of the pedal arm with the plunger pushed against the arm thus keeping the switch contacts open.When you depress the brake pedal the switch plunger will extend outward and the switch will close turning the lights on.
  12. need louvers ?
    need louvers ?
    Nothing wrong with a pressure switch... Except the quality level of most switches today. The cure is to hit a VW shop and pick up a Bosch hydraulic switch for any year BUG. Got the good BOSCH branded stuff and it'll last longer than you. Double bonus is that it trips at a lower pressure value, so you brake lights come on quicker.
  13. A Boner
    A Boner
    I've heard that Harley Davison has them figured out.....they work at very low pressure, and are reliable.
    need louvers ? likes this.
  14. need louvers ?
    need louvers ?
    I've not used one yet, but I have been told the same thing.
  15. gimpyshotrods
    gimpyshotrods
    If your system is properly bled, it does not matter where a pressure switch is. The pressure in a hydraulic system is equal at any measured point, and pressure changes are instantaneous, an simultaneous.
    Smokey Stover and Hnstray like this.
  16. themoose
    themoose
    Not totally true....Depends on the tube/pipe material. With flexible hose, there is always some expansion of the diameter when under pressure. This will cause a greater delay time in building up pressure and taking pressure off when the length of the tube is very long. But, with small bore (relatively inflexible) stainless steel tube, there will be practically no swell of the diameter and the pressure will go on/off almost digitally - even at great lengths - to the extent that the hydraulic fluid is incompressible.
  17. Dino 64
    Dino 64
    from Virginia
    Mechanical. Watson's Street Works. Stainless, no problems. Do you want to bleed your brakes for a switch ?
  18. FrankenRodz
    FrankenRodz
    I just answered the same thing on a Fairlane Thread.
    Simply add a junction block, with one port for the brake line, and one port for the switch.
    Junction block was a few bucks @ Autozone!
    It's real easy, and contrary to what some others may think, it works great!
    I've got well over 1k miles on my Fairlane with no issues.
