brake reservoir hose
Discussion in 'The Hokey Ass Message Board' started by supervert, Mar 6, 2013.
  1. supervert
    supervert
    so i have been looking for low pressure brake hose for my remote reservoir. struck out at napa (they tried to get me to buy fuel hose), and the vw places want $5 a foot. so i was just going to order it from mcmaster. well today my wife sent me to get some chicken food from tractor supply, and wile wandering through the isles i decided to see what they had. well they just happened to have epdm in about every size from 1/4" to 1". so i got 10' of 3/8" for $10, with is a lot cheaper than the $40 it would of cost at bugformance or mcmaster.
    so, if anybody is doing a rem. res. for a clutch or brake master just look in the pump sprayer section at tractor supply.
  2. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Gotta love Tractor Supply!
    Nuts and bolts by the pound, only way to buy them!
    KK
  3. CutawayAl
    CutawayAl
    from MI
    I know of many cases where fuel hose has been used with brake fluid. Unless things have changed, flow pressure fuel hose(for carbureted engines) is neoprene. Neoprene is not adversely effected by DOT 3 and DOT 4 brake fluid.
  4. supervert
    supervert
    Neoprene was the first synthetic rubber developed commercially and exhibits generally good ozone, aging and chemical resistance. It has good mechanical properties over a wide temperature range.
    Heat resistance
    Up to approximately 250°F (121°C).
    Cold flexibility
    Down to approximately –40°F (–40°C).
    Chemical resistance
    Paraffin base mineral oil with low DPI, e.g. ASTM oil No. 1
    Silicone oil and grease
    Water and water solvents at low temperatures
    Refrigerants
    Ammonia
    Carbon dioxide
    Improved ozone, weathering and aging resistance compared with nitrile rubber.
    Limited compatibility
    Naphthalene based mineral oil (IRM 902 and IRM 903 oils)
    Low molecular aliphatic hydrocarbons (propane, butane, fuel)
    Glycol based brake fluids.
    Not compatible with:
    Aromatic hydrocarbons (benzene)
    Chlorinated hydrocarbons (trichloroethylene)
    Polar solvents (ketones, esters, ethers, acetones).
  5. supervert
    supervert
    EPDM (Ethylene Propylene, EPM)
    EPM is a copolymer of ethylene and propylene. Ethylenepropylene-diene rubber (EPDM) is produced using a third monomer and is particularly useful when sealing phosphate-ester hydraulic fluids and in brake systems that use fluids having a glycol base.
    Heat resistance
    Up to 300°F (149°C) (max. 400°F (204°C) in water and/or steam).
    Cold flexibility
    Down to approximately –70°F (–57°C).
    Chemical resistance
    Hot water and steam up to 300°F (149°C) with special compounds up to 400°F (204°C)
    Glycol based brake fluids up to 300°F (149°C)
    Many organic and inorganic acids
    Cleaning agents, soda and pot***ium alkalis
    Phosphate-ester based hydraulic fluids (HFD-R)
    Many polar solvents (alcohols, ketones, esters)
    Ozone, aging and weather resistant.
    Mineral oil products (oils, greases and fuels).
