Technical Brake Setup Help Needed
Discussion in 'The Hokey Ass Message Board' started by Shovel96, Dec 20, 2022.
  1. Shovel96
    Shovel96
    I need some guidance on what to do for brake set up. I am building a studebaker pickup with a 327, automatic, with disc brakes up front, and drum brakes in rear, all gm. I am trying to figure out what setup to go with. Any suggestions would be helpful. I have been looking at Wildwood sets but don't know what to choose.
  2. Happydaze
    Happydaze
    My stab in the semi darkness is a 1 1/8" master with an 8" dual booster. You'll want the pedal ratio in the 5+:1 region with about 1 1/2" of throw. Wildwood is just a brand, a good brand, but there are any number of sources. Generic 'corvette style" master is what you'll probably end up with.
    Chris
  3. sunbeam
    sunbeam
    If the disk and the rear axle came from the same vehicle I'd copy the factory setup as close as possible.
  4. TA DAD
    TA DAD
    from NC
    On my Studebaker truck I used all the components for a 75 Camaro/Firebird manual disc drum set up. That includes rotors, calipers, proportioning valve and the wheel cylinders. The truck weighs about the same as a Camaro and it has excellent brakes.
    lowrd and deucemac like this.
  5. Try ECI brake in Vernon, Connecticut. They make many disc brake conversions using quality products at reasonable prices.
    bschwoeble likes this.
  6. manyolcars
    manyolcars
    Brake problems are so common that we need a sub-forum f0r brakes only.
  7. They still wouldn't search and read before asking the same thing over for the 1000th time.
    bschwoeble, sdluck and lostone like this.
  8. alchemy
    alchemy
    Disc in front and drums in rear, all GM. Easy answer is get the pedal and master from the same vehicle you got the brakes from.
    Don’t know what they are from? Then anyone’s recommendations are going to be a shot in the dark.
    Rocky and Tman like this.
  9. KULTULZ
    KULTULZ
  10. lowrd
    lowrd
    Read about as many threads as you can handle on the subject. The TA DAD/alchemy suggestion of using a complete system from a donor vehicle is good info. I used a similar year Camaro setup on my 53 Chev sedan and it works well. I did keep the master under the floor and had to use an adjustable length push rod to get the feel right without having to pump the brakes to stop.
    Tman and Mimilan like this.
  11. Mimilan
    Mimilan
    Buy a rusty G body donor car and get everything from that ( including the rear end)
    Then rebuild what is needed.
    Tman likes this.
