Brake shoes - which direction ?
Discussion in 'The Hokey Ass Message Board' started by Johnnyzoom, Jul 2, 2009.
  1. JohnEvans
    JohnEvans
    from Phoenix AZ
    Barry2952: Yes your W/C are backwards ,early Fords big dia is always to the front.
  2. barry2952
    barry2952
    Which shoe faces the front of the vehicle?
  3. Mart
    Mart
    Ok, stop right there!
    Early ford are different to the later self energising types (like the illustrations above.).
    Early ford have the bigger diameter end of the cylinder and the longer shoe towards the front. This goes for front or rear.
    Self energising have the short show towards the front. (BOB Big on back like said above)
    The Early Ford brakes shown should have one short shoe and one long one. Looks like 2 long ones both sides. You should cut two back to make short ones.
    Edit: replied at the bottom of page 1 without seeing the replies on page 2. Doh!
    Mart.
    tb33anda3rd likes this.
  4. johnny bondo
    johnny bondo
    from illinois
    nope. think of F1 as the brake line, and F2 as the cylinder, and imagine another F3 even bigger. the force would further reduce every time it got bigger.
  5. 31Dodger
    31Dodger
    Is that a factory manual or aftermarket?
  6. 28hiboy
    28hiboy
    from Milton, Fl
    It's easy---the big shoe chases the little shoe. Just like in real life.
  7. V8 Bob
    V8 Bob
    Pressure out of a master cylinder will increase as the bore is reduced with a given force input. P = F/A
    Force
    out of a wheel cylinder will increase with a larger bore and given pressure input. F = P x A.
    K?
    dirty old man likes this.
  8. flathead4d
    flathead4d
    On Fords (1948 and back) the long shoe goes to the front. After 48 the short shoe goes to the front.
  9. chaos10meter
    chaos10meter
    from PA.
    Well
  10. Godspeed
    Godspeed
    Sorry to ask years later, but I came across this issue.
    I bought all new shoes for my '65 F-100.
    Front brake went on easy, small lining in front large lining in back.
    When I looked at the old shoes on the rear, the front lining was short and the rear lining was long.
    The replacement shoes had equal length linings and identicle part numbers. Friction material looks the same on all four shoes -they look identicle.
    Called the parts guy and he said that a lot of shoes are coming in this way now, not to worry. I tried them and it seems O.k.
    Shoud I worry:confused:
  11. Christom
    Christom
    Yep - that's "right" - for a RHD car. I've seen that picture - New Zealand is a RHD country as this is correct for here! Sure does knock your confidence when the manual is **** about face! :confused:
  12. I'm trying to sort out all this "long shoe, short shoe" business. Is this the correct answer? (I'm working with '46-48 car brakes.)
  13. COCONUTS
    COCONUTS
    Hey not to highjack this site, but it looks like he has the answer, but how about this, regular points dist. common coil (don't asked internal or external resistor) with the white block byp*** resistor, which side of the coil, positive or negative goes to the dist. I can never remember, and can never find it in any motor repair book, when I need it. I am willing to take a verbal beating over this, and after that I will remember....thanks
  14. rusty1
    rusty1
    ...just think of em as "big & littles" as in tires, bigs on the rear.
    pat59 likes this.
  15. Dan Timberlake
    Dan Timberlake
    Hi Coconuts,
    You really ought to start a new thread about your ignition coil polarity question .
    This is how I'd wire it for a Negative ground system.
    http://i176.photobucket.com/albums/w164/onlycubcadets/KohlerIGN-1.jpg
    regards,
    Dan T
  16. Nailhead Jason
    Nailhead Jason
    I get two sets of shoes for the front wheels of self energizing brakes and put long shoes on front and back. might not be needed but in my feeble mind it seems like more shoe equals more stopping power. i have noticed a increased stopping power but then again i had just rebuilt all the brakes too.....
  17. flathead4d
    flathead4d
    Fords 48 and back long shoe to the front. Fords 49 and up short shoe to the front. That's my answer and I'm sticking to it.
  18. Thanks, Flathead. I believe you're correct. OK boys, back to the shop. ;)
  19. slowmotion
    slowmotion
    ^^^ That's a good way to remember it. I like little tricks like that, good one man.
    clem likes this.
  20. bobss396
    bobss396
    This is something I learned a long time ago and I'll say that some people should not be doing brakes... and this applies to a few people who I've seen that do them for a living.
    Truck64 and tb33anda3rd like this.
  21. Truck64
    Truck64
    from Ioway
    Don't believe so, but it is annoying Remember a pickup (unloaded) is prone to locking up the rears easily?
    Ran into the same issue with 64 F100, the replacement shoes for the rears were all the same length (and material) lining, I ***umed RA had sent out a mismatched set or return or something.
    Went out to an auto parts store and had the clerk pull a couple sets off the shelf and we checked, all of them had the same length lining shoes as well for the rear axle. Front axle sets had both a short and long as advertised.
    So I installed them. Not sure why the switch by the manufacturers. Seem to work good, they needed some time to "bed in" and wear all around but that's not news. Right on time, a few weeks later I had a real honest to goodness panic stop situation at highway speed and the truck stopped on a dime, all 4 drums locked up at the end. The servo or "self energizing" feature works good, though with manual brakes it takes a little bit of effort. Very confident in these brakes (now). I spent a small fortune replacing everything but the pedal, and paid for itself in about a half second.
  22. Atwater Mike
    Atwater Mike
    BRAKE SCHOOL. Eons ago, when cars had mechanical, then modern hydraulic brakes, there was a steadfast rule.
    The longer shoe, (or the one with 'harder lining') went against the ANCHOR PIN.
    (car going forward, of course) The smaller shoe acted as a 'servo'. The shoe against the pin was the 'working shoe'. Consider the leverage physics. One quick look will do it.
    The previous illustration is of a right rear brake, Bendix type. Note the anchor pin.
    Truck64 likes this.
  23. theHIGHLANDER
    theHIGHLANDER
    Ok, now that we have that all sorted, who can tell me why certain models of Packard have shoes 1/4" narrower on the left front than on the right or both rears? The answer after our commercial break...
  24. theHIGHLANDER
    theHIGHLANDER
    Lower left corner of this picture shows why:
    That spring pack within the left rear mounting of the front spring eye does a masterful job of removing shock from the steering wheel should rough conditions or bumps get encountered. The axle will move vs the steering wheel. With the advent of this feature less width was used on the left front shoes to avoid excess (equal) brake friction which would have the vehicle pulling left when braking. Elegantly simple and effective. The brake system is so large as it is that no loss of brake performance will ever be encountered, and the power ***ist was also welcome with such a heavy car.
  25. This seems somewhat related to this thread. I am ***embling a 1941 Ford rear axel owner installed under a 1936 1/2 ton pickup in the 50's. I've got a pair of very nice, freshly turned original drums, brand new wheel cylinders, and a set of brand new Drake shoes. They are ***embled like the correct side above on Barry2952's '41 pickup and regardless of cam adjustment, the drums won't go over the new shoes. I'd rather not go find a shop that can re-radius the friction material (if anyone even still does that). I am new to early Ford V8 brakes. Is there a trick?
    SEVERAL HOURS LATER!
    Well, for the benefit of all you virgins out there, 1937 to 1948 Ford rear axels have "FOUR" (4) brake shoe adjusting cams, two that index in the bottom of the shoes and two up near the top that those two big spring retained bolts sticking out of the backing plate adjust! You have to adjust them all to get your new shoes to fit!
    Sorry I blew up, but as my signature suggests, good training is never free. This lesson only cost me about 4 hours.
    Hnstray likes this.
  26. seb fontana
    seb fontana
    from ct
    37 to 45...46/47/48 had no bottom adjusters just pins.
  27. jimmy six
    jimmy six
    Hard to find someone today to arc the shoes to fit the drums. Sometimes I do it myself with a body file. Alway remember to chamfer the leading edge of each shoe to stop squealing. You don't need to do both edges like the details above show. A wood rasp works pretty good for doing this... Oh yeah don't breathe the dust...good luck.
  28. Mart
    Mart
    Most shoes are made quite thick as the makers expect the drums to have had one or two skims by now.
    Mart.
  29. ct1932ford
    ct1932ford
    Time to bring this back. I am putting Boling Brothers brakes on my coupe. It does say in the instructions that in the rear the longer lined shoe goes to the rear. Does that mean the front should be the same? I know the early Ford brakes always had the long shoe in the front.
