brake switch question
Discussion in 'The Hokey Ass Message Board' started by rick3658, Sep 3, 2013.
  1. rick3658
    rick3658
    from wisconsin
    I have pressure switch that has two round contectors on it does any one know where I can buy a pig tail to hook them up?? Is there any type of conector I can buy local to plug onto it. Tiered of hearing brake lights not working and it is just because I cannot get a tight plug on it.
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Any auto parts store worth the dirt they are built on will have those connectors.
  3. d2_willys
    d2_willys
    from Kansas
    Aren't they just bullet connectors? Perhaps you have the wrong size mates?
  4. rick3658
    rick3658
    from wisconsin
    not sure i have ever seen bullet cont. any why you can tell me what they look like
  5. bangngears
    bangngears
    from ofallon mo
    You can also just solder leads on them.
  6. mike in tucson
    mike in tucson
    from Tucson
    A bullet connector is sometimes called a Ford connector since Ford uses so many of those shapes. Look closely at your switch. Are the pins straight with no little turret on the top? If it has a little turret, it may be a solder lug connection. Do a google for "Ford connectors" and "bullet connectors"...if you do a search for the exact phrase, lots of hits come up.
  7. bchrismer
    bchrismer
    If it's a hydraulic switch, it may be an issue with the pressure rating of the switch, rather than the connections. When I had a standard pressure switch in my '40s, I had to be nearly stopped, with heavy pressure on the switch, before the lights would even come on.
    Do yourself a favor, run to the nearest Harley shop and buy a hydraulic switch from them. Motorcycle switches have a much lower PSI rating to them, and will come on much earlier.
    HD part number: 72023-51E (USA Made, too) Last one I bought was about $22, after tax.
    I'm running one in both of my '40s. They have two blades and they supply you with the connectors for them.
  8. rick3658
    rick3658
    from wisconsin
    Can do that like the thiought of being able to unplug if needed and usa made thanks
  9. Inked Monkey
    Inked Monkey
    I'm using the Harley switch to. Simple to switch out and easy to hook up with a couple female spade terminals. My brake lights come on a lot sooner than before!
  10. 325w
    325w
    Find a connector for an old A 6 compressor. I think it will fit and splice on to the brake wires. The terminals are GM 56 series.
  11. Mike Moreau
    Mike Moreau
    Is the fitting on the Harley switch the same as the Ford type? Thanks
  12. rustang
    rustang
    +1.... I'm running a hydraulic brake switch out of a Polaris snowmobile... super cheap and lots out there..
  13. mink
    mink
    from CT
    Why not run the popular mechanical brake light switch
  14. bchrismer
    bchrismer
    Yup. As if it were made for hot rods!
  15. JohnEvans
    JohnEvans
    from Phoenix AZ
    And just to further confuse the issue the Ford pins are .187 dia. and normal ones are .153 or so , 2 different sizes for sure .
  16. kcbeardclub
    kcbeardclub
    from KCMO
    I've got the same bullet connectors and they kept popping off, I ended up soldering them on. Brakes are a pain in the a$$ for sure.
    T
  17. Mike Moreau
    Mike Moreau
    Thanks Bchrismer for the info on the fitting sizes. Got to thinking about using a HD switch or other lower pressure switch: Is there a danger of blowing the low pressure switch apart, causing a brake failure? The HD low pressure switch has different requiremets therefore different engineering specs.
  18. Inked Monkey
    Inked Monkey
    Umm, my Harley switch does not have bullet connectors on the top. It's using plain spade connectors.
  19. VoodooTwin
    VoodooTwin
    from Noo Yawk
    No. Low pressure just means that the switch activates at a lower line pressure than the other types. So your lights come on sooner.
  20. 1971BB427
    1971BB427
    from Oregon
    Went through the same PITA when I completely rewired my '63 Falcon recently. Nobody around here had the correct connectors, so I found myself digging through the s**** pie and grabbing all the old connectors from the Falcon. But I found even Ford doesn't use the same size everywhere, as some fit, and some were the wrong size.
    I finally found two good ones and soldered them to my harness to keep them as a plug in style.
  21. CHANGE the switch to one with more positive connections
  22. 26 roadster
    26 roadster
    an amazingly simple fix.....................I use VW that has two spades.
    Use what you have fittings for, they are all just switches and have no idea what they are going in.
  23. Quit over complicating this , take a simple pair of pliers , and gently pinch down the ends (while unplugged , ) then plug 'em back on,
  24. d2_willys
    d2_willys
    from Kansas
    Digikey has them for .38 each. .180 diameter, and insulated.
  25. Okay, so I see a lot of HD switches that are part #72023-51 *A*- would that be the same as the #72023-51 *E* ? They seem to be more inexpensive... I don't want to scrimp on having brake lights, but if they are virtually the same... 8=)
  26. woodiewagon46
    woodiewagon46
    from New York
    Ron Francis Wiring has the pigtails you need.
  27. 40FordGuy
    40FordGuy
    The HD switch seems to be the best choice....When you buy it, get the connector that goes with.
    4TTRUK
  28. bchrismer
    bchrismer
    Agreed. The main difference is in the spring inside the switch. The lower pressure switch uses a lighter spring.
  29. 48FordFanatic
    48FordFanatic
    from Maine
    Get rid of the pressure switch and use a GM style plunger switch that contacts the brake pedal. Much better design , can be installed out of the elements ,and is a proven reliable switch by GM.
  30. rustang
    rustang
    I think on a frame mounted master, under the floorboards, a pressure switch is a much cleaner installation. Tough to mount a plunger switch to the floor in an early car/truck and have it look clean.
    I could see on a firewall mounted master this being a good solution...
    Tom
