Technical Brake switch
Discussion in 'Traditional Hot Rods' started by dirt t, Aug 3, 2023.
  1. dirt t
    dirt t
    Looking for the connector for brake light switch. Part number and a source please
    Thank's
    Terry aka dirt t
  2. Bob Lowry
    Bob Lowry
    Here you go..from Jegs, part number 764-80174 and others....
    VANDENPLAS likes this.
  3. bobss396
    bobss396
    I likely have one around here like that. I replaced it with a OG push-on switch, I didn't think that connector would stay on.
    Bob Lowry likes this.
  4. squirrel
  5. 325w
    325w
    Alternator plug should work
    squirrel likes this.
  6. bangngears
    bangngears
    from ofallon mo
    Solder them, then cover with shrink sleeve. Will not come off
  7. RmK57
    RmK57
    I heard from on here people were having issues with that style of brake light switch. Either they don’t work at all or start leaking around the crimp. I’ve only ever used the style that attaches to the brake pedal arm.
    Sporty45 likes this.
  8. squirrel
    They fail pretty often, so soldering is probably not the best approach...
  9. goldmountain
    goldmountain
    Back when I worked for my friend Abe, at the auto wreckers, I would harvest one of those from an old GM a/c compressor on the friendly employee five finger discount plan. This time around, I needed one for the neutral safety switch so I ordered one from American Autowire. When it arrived with the cost of shipping, I realized that the older plan was much ore affordable.
  10. manyolcars
    manyolcars
    Tman and VANDENPLAS like this.
  11. deucemac
    deucemac
    Just an added note. I am running silicone brake fluid and that type of brake light switch. I went through several with leakage problems from the silicone. I went to a Harley Davidson brake light switch because Harley uses the same switch but uses silicone fluid. All my problems stopped right then. The last switch lasted 10 years before failing, so I couldn't blame silicone for the failure. I have 3 years on the current one.
  12. Can you supply a HD part number ?
  13. Garpo
    Garpo
    Ordinary 1/4" blare terminals work. Push on from the side.
  14. bobss396
    bobss396
    My Ford I have set up to go with a pedal-switch if I need to. I can just run my spare BL wires back through the firewall. I should get a pedal switch and plan for that option.
  15. I completely agree, however, go to the Harley dealership and buy an OEM switch, DO NOT buy an aftermarket one. The Harley part number is 72023-51E. The 51 at the end indicates it came out in 1951, but the E indicates it has been updated 5 times. The current price is about $33 for this switch at the dealership, however how many times do you want to have to replace a ****ty one and re-bleed the brakes?
  16. CSPIDY
    CSPIDY
    Ron Francis sells a high quality switch
    AccurateMike likes this.
  17. Wizard1926
    Wizard1926
    +1 for the Ron Francis switch.
  18. chickenridgerods
    chickenridgerods
    from DSM, IA
    A real PITA when the switch decides to **** out, though, even if you utilize connector to hook it up to the ch***is wiring harness.
    Better option: Avoid using this style of switch entirely and use a mechanical one instead.
    Tman, Ned Ludd, egads and 1 other person like this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Do " other types of switch" use better connectors ?
  20. bobss396
    bobss396
    I use one from eBay, it trips at around #25 and I have had it in the car for 5 years. I bought another and have saved the seller. It still sits in the glove box. I think it was around $14 for the last one I got. The Napa one was pure junk, many things I got from Napa have taken a dump on me.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Same with the Speedway iteration .
    dirt t likes this.
  22. manyolcars
    manyolcars
    did you look at post #10?
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    One kind of push on vs another type of push on ? Both rely on friction to stay connected , having used both types many times in many situations , I don't see an advantage to either . I'm of a mind switch secure mounting position & wire routing are far more important .
  24. squirrel
    did you look at post #4?
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Was it more than 10 minutes ago ? But yes , the 2 types of terminals being discussed were t-/spade & male & female bullet . there were no further comments about threaded contacts that Im aware of .
  26. Happydaze
    Happydaze
    72023-51E is what I have. I think their hydraulic switches are all the same. Iirc there was an improvement in the design which resulted in a slight part number change. I recall having no part number when at the dealership but they knew immediately the part required. Its a 1/8 npt thread. Mine has regular female blade connectors.
    Chris
    deucemac likes this.
  27. dirt t
    dirt t
    Thank you
    Terry aka dirt t
  28. bobss396
    bobss396
    I got the OG-ish Ford push-on connectors from The Wiring Depot, similar to solenoid ones. They really stay on well, I check them now and then. The other one that was 1st pictured, confidence was not high for me. Go with what you know.
  29. chickenridgerods
    chickenridgerods
    from DSM, IA
    The most common ones use the bullet style terminals, although you can find others. The real benefit is they won't leak brake fluid and if it does **** out, you don't have to crack open your brake system, risk fluid leaks, and then re-bleed.
    caseywheels likes this.
