Technical Brake system
Discussion in 'The Hokey Ass Message Board' started by angelotti86, Oct 30, 2015.
  1. angelotti86
    angelotti86
    I am attempting to upgrade my brake system and I and getting a new master cylinder and booster .My question is there appears to be some type of a red sealant around each connection thread going into the master cylinder and all others .I have tried searching but cannot find what this is and if it should be used .In the past I have used the Earls thread sealant but what to make sure what is proper .
  2. angelotti86
    angelotti86
    Also forgot is better to go with 1" bore or bigger size for better braking .They are power brakes .
  3. indyjps
    indyjps
    What car, disc / disc, drum / drum, disc / drum. Are the brakes stock now?
  4. angelotti86
    angelotti86
    Front disc but will be upgrading front and rear disc when I do the rear end.The brakes are not stock
  5. geoford41
    geoford41
    from Delaware
    Not positive but the "red" maybe some sort of anti-seize, the Seal on most master cylinders usually depend on the inverted flare metal to metal as a seal and not a sealant per say. Others may have some input on this.
  6. woodiewagon46
    woodiewagon46
    from New York
    Two products made by Loctite fit your description. Loctite 545 Pneumatic/Hydraulic Seal and Loctite 569 Thread Sealant.
  7. angelotti86
    angelotti86
    Thanks for the reply
  8. angelotti86
    angelotti86
    Is there any issue with using a manual master cyl on a brake booster .I found what was originally used on my truck and its what they are calling a manual master cyl but it bolted up to the booster fine .The reason i would like to use it is cause there is a fill hole drilled perfect to fit that combo.
  9. angelotti86
    angelotti86
    these are the two I have to choose from but the manual brake is one they had on it originally .What is the difference between the two ?
    Dorman® - Brake Master Cylinder (With 2 Outlets)
    Ford Mustang Manual Brake System 1978, Brake Master Cylinder With 2 Outlets M85365 by Dorman®. Bore Diameter: 15/16"; Forward Outlet Size: 7/16"-24; Rearward Outlet Size: 9/16"-18; With Reservoir; Material: Cast Iron; without Sensor; For FMSI:. Dorman’s...
    Fits Following Model(s):
    • Manual Brake System
    SKU:
    17848879
    Price:
    $42.31
    Qty:
    Delivery:
    $42.31
    Remove Item
    Ford Mustang Power Brake System 1978, Brake Master Cylinder With 2 Outlets M36445 by Dorman®. Bore Diameter: 15/16"; Forward Outlet Size: 3/8"-24; Rearward Outlet Size: 7/16"-24; With Reservoir; Material: Cast Iron; without Sensor; For FMSI:. Dorman’s...
    • Power Brake System
    SKU:
    17848880
    Price:
    $28.26
    Qty:
    Delivery:
    $28.26
    Remove Item
  10. Happydaze
    Happydaze
    A master cylinder is a master cylinder - it doesn't know what's operating it. The manual will have a much deeper hole for the actuating rod so that it won't fall out. To use a manual with a booster this hole needs to be filled with a bullet type piece - make or buy. Don't forget the output from the booster is adjustable and it's absolutely critical that it is set up correctly.
    Chris
  11. angelotti86
    angelotti86
    I am having a very hard time finding a 3/8 24 to 1/8 male npt fitting for the master cyl i bought to attach my brake line .Does anyone know where to find one ?
  12. Plootz
    Plootz
    Try NAPA they have the hardware to match brake lines. Fittings usually come with fittings
  13. Plootz
    Plootz
    Correction mast cyl usually come with fittings. The red stuff is thread sealer and everything I have gotten with the sealer on it says do not use thread sealer of Teflon tape.
  14. Kerrynzl
    Kerrynzl
    The bigger the bore...... the better the ABS effect you have when you late-brake into a corner
    [ it is a learned skill :) ]
  15. 55willys
    55willys
    The master cylinder needs to be sized to fit with the calipers you are using. What size are the pistons in the calipers? What did the calipers come off of originally? What is your pedal ratio? If you can answer these questions I can give you a recommendation as to the bore size that will work. If you can give me the original application I can look it up that way.
