Technical Brake Trouble..
Discussion in 'The Hokey Ass Message Board' started by Tom Nimmo, Apr 9, 2014.
  1. Tom Nimmo
    Tom Nimmo
    Ok here's the Story..
    I have a 49 Plymouth on a GM Full Frame.. (Which I am as yet unable to Identify model and year, Any help there would be greatly appreciated)
    It has Drum Brakes on all 4 and I am planning on upgrading to Disks if I can at some point determine what my frame is.. Ok I'm Rambling..
    Have crate motor, PS, PB, AC etc.. Brake setup is off something with disk brakes, dual reservoir, 11 1/2" Booster.. Issue is the brakes are so touchy that if your not really careful you end up with your nose on the windshield..
    I am aware that I am over boosting the Drum Brakes.. The would usually require 500psi Boost and the booster I have puts out 1000psi that's required for Front Disks.
    Question is... Will installing a smaller size booster, Like a 9" help with this?
    Or does someone make an adjustable metering Valve? or? Or do I live with it until I can identify the frame and get my Disk Conversion?
  2. Firecat7
    Firecat7
    lifting the world with a lever 9 miles long, will take more effort than one 11 miles long. lol.. sure 9 will be better( less push)
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    What is the MC bore size? A larger bore MC will give lower line pressure,if you have say a 1" going to a 1-1/8 will help. If it is already 1-1/8 a smaller booster is all you cand do.
  4. Tom Nimmo
    Tom Nimmo
    It's an 1-1/8 already..
    I bought a smaller booster, And I guess I will install it when I Rewire the car as I am planning installing a new Steering Column then as well.. I'll let you know how it works!
    Now.. Who's the "Frame Guru" Round here?
  5. Firecat7
    Firecat7
    you may try restricting the vacuum some now....drill a dowel with an orfice n insert in the hose. no money ,not much work. giv'er a try
  6. bgaro
    bgaro
    we're gonna need to see pix of that frame and front suspension.
  7. Ulu
    Ulu
    from CenCal
    Is there quite a bit of travel in the pedal with no effect, then they just suddenly want to grab?
    Maybe the proportioning valve needs to have a check valve (residual pressure valve) with it. Do these brakes "cross over"? (LR same hose as RF, RR same hose as LF?)
  8. oldolds
    oldolds
    Take the booster out completely. You might be suprised how no power brakes works.
  9. What kind of pedal ***embly do you have? What is the pedal ratio? A long pedal arm that gives you lots of leverage may mean you don't need a booster. The master cylinder doesn't know or care whether it's being boosted by a vacuum booster or the mechanical leverage of a long pedal arm.
  10. Tom Nimmo
    Tom Nimmo
    It's a short pedal from a disk brake setup..
  11. Firecat7
    Firecat7
    LOL...oldolds, has the best first try.STOP OUT THINKING THE PROBLEM. Try OLDOLDS IDEA, unhook vacuum line , pull out fitting(important) at the booster.... plug engine vac side or pinch hose with vise grip, and give it a try, may work without power. or reduce vac supply like one suggested.;)
  12. fms427
    fms427
    Yep - to beat a dead horse - you have way too much booster for drum brakes. I would remove the booster totally - but you may have to increase pedal ratio ( you probably have 3.5:1, need about 6:1 ) and/or decrease master cyl size if pedal is then too hard. Might be easier to just do the disc brake conversion - but you will still have to play with sizes and ratios depending on what wheel brakes you use. Brakes aren't "one size fits all"........ :D
  13. Dapostman
    Dapostman
    I had this same problem, the remedy is to replace the slave cylinders with a smaller ones, we replaced a 1 1/8” cylinder with a 1” front and a 15/16” with a 7/8” rear on a jeep dispatcher. Unless you can physically look at them at your local parts store it can be difficult to find the right number. If you know the original cylinder number I may be able to figure the corresponding smaller cylinder numbers.
