Technical Brake tubing close bend
Discussion in 'The Hokey Ass Message Board' started by kabinenroller, Nov 6, 2022.
  1. Just.dale
    Just.dale
    '28phonebooth likes this.
  2. gimpyshotrods
    gimpyshotrods
    I have the spring benders too. They just don't go down that small. Otherwise, those work well for larger stuff!
    And yes, two birds! With gravel guard, well, you get a gravel guard!
    Just.dale likes this.
  3. kabinenroller
    kabinenroller
    I shot a photo of the fixture that I fabricated, in my previous post it was difficult to see the mandrill.
    The unit clamps in a vice when using it.
    KoolKat57, reagen, bobss396 and 8 others like this.
  4. nochop
    nochop
    from norcal
    I’ve also put smaller sections filled with water in the freezer
    ekimneirbo and '28phonebooth like this.
  5. nochop
    nochop
    from norcal
    Nice solution to making a tight bend with the fittings in place
    Los_Control likes this.
  6. fabricator john
    fabricator john
    from venice fl.
    the plier type i have several sizes i got from matco make super tight bends right at the nut ,,
    fabricator john
    miss you dad
    nochop likes this.
  7. Beanscoot
    Beanscoot
    It looks like a guy could get the grooved "die" piece from the center of an old bearing:
    Which of course now means that I can't even throw old damaged bearings away.
  8. Dave G in Gansevoort
    from Upstate NY
    And I feel your pain! SWMBO doesn't understand why I keep the stuff that I do.
    I've said it before, it's a sickness! But I like these ideas. Guess what I'll be doing in the near future...
    X-cpe likes this.
  9. X-cpe
    X-cpe
    Great and effective tool. If you need to get an even tighter bend you could notch the mandrel to get the nut closer to the start of the bend. ( If there is enough meat to avoid getting into the bolt hole.) From the pictures it looks like there is at least 1/4"+ to be gained. Another gain of about 2/3 to 3/4 of the tube diameter could be had by making a presser arm, outer mandrel (like the first and third benders in your original picture) to keep the tube all the way into the center mandrel as it completes the bend.
  10. They use that method for bending br*** tubing for trumpets and trombones.
  11. Elcohaulic
    Elcohaulic
    I use speedo cable it has 360 degrees of rotation. If I want the bend to stay straight I use electrical fish line, it only moves for and aft. If I need it to be thicker I put vacuum hose over top of it. I spray WD over everything. Especially vacuum connections where hose goes over tubing.
    It's still a hard thing getting tubing just right some days I have one piece in the barrel and other days it's allmost full.
    There's a lot of very talanted builders on here.
    X-cpe likes this.
  12. Greg Rogers
    Greg Rogers
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No one remembers the original Flight of the Phoenix with Jimmy Steward? They filled tubing with sand.
    nochop and Elcohaulic like this.
  14. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Maybe it works with smaller tubing, but I tried it on exhaust pipe using a hydraulic pipe bender and didn't have any luck. It seems like it should have worked fine........but it didn't. Maybe its just me :D
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The thing is sand needs to be packed tight and ends of tubing capped with zero voids in the sand for it to work correctly.
  16. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Yes, I packed it as tight as possible, but the pipe was kinda long. Then I welded caps on each end.........but I still screwed up the pipe. Tried it a couple of times and had no luck. Just saying, that I had a nice hydraulic bender with a smooth bending action and I couldn't get it to work for me. Maybe a smaller size pipe and hand bending would work.:)
  17. bschwoeble
    bschwoeble
    Has to be one of the best tips ever. Thanks.
  18. seb fontana
    seb fontana
    from ct
    I tried sand several times with various size tubing and never got good results. Even bending around a v-belt pulley worked better..
    ekimneirbo and gimpyshotrods like this.
  19. lostone
    lostone
    from kansas
    I've seen some tube bent with sand and wasn't impressed. I always wondered if you used really wet sand and packed it if the wetter sand would pack tighter and hold firmer thru the bend.
    It's one of those great ideas I've had but never got around to trying, some ideas I had when I was younger and never got around to trying probably saved me from hospital visits!
    ekimneirbo and seb fontana like this.
  20. TRENDZ
    TRENDZ
  21. nochop
    nochop
    from norcal
  22. Roll it over a 1 in Socket that is the correct size
  23. gimpyshotrods
    gimpyshotrods
    If you have not come up with an adequate solution by now, let me know.
    You can borrow my little Imperial tool. It is still brand new in the package.
    There isn't a whole lot of call for quarter inch in my, so getting it back to me is not a huge hurry.
    I can mail it to you, and you can mail it back when you're done.
  24. kabinenroller
    kabinenroller
    Thank You for the generous offer, in a previous post I explained that I fabricated a tool that made a bend tight enough to fit.
    <a href="https://www.jalopyjournal.com/forum/threads/brake-tubing-close-bend.1278583/#post-14669086">Brake tubing close bend</a>
    The photo of your Imperial tool was helpful when I was figuring out how to make mine. The flare nut screws into a threaded hole that protects the thread and hold the tubing tight against the mandrel during the bend.
    As of yesterday I have completed the brake line installation so now the next step is filling the system, bleeding and hopefully no leaks. I have Speed Bleeders installed to simplify the process and because I work alone with no helper to pump the brake pedal.
    gimpyshotrods likes this.
  25. gimpyshotrods
    gimpyshotrods
    Good that! I totally missed that the previous post was you, and did not want to leave you stuck!
