brake update for banjo
Discussion in 'The Hokey Ass Message Board' started by hotrod8, Jan 6, 2010.
  1. hotrod8
    hotrod8
  2. Fogger
    Fogger
    You put a lot of thought and good engineering into this brake setup. Nice lowbuck upgrade for the application. With the big binders on the rear you could need a proportioning valve. But needless to say a good inexpensive job.
  3. Nice job! Thanks for sharing.
  4. kirby1374
    kirby1374
    wow good job of adapting to something that you can get parts from any parts house. cool
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Great job. This would actually work on any 28-48 Ford Passenger Car OR 28-47 Ford 1/2 ton Pickup/Panel rear end.
    You would need to check the 28-31 A rear end spring perch clearance to the cylinder brake pipe inlet on this before committing to it just like the early Ford conversion.
    How about a shot from the rear installed?
  6. kentuckyscum
    kentuckyscum
    from kentucky
    Nice job! Exactly what I was looking for.
  7. Vergil
    Vergil
    Great post ----------- Big Thanks!
    Vergil
  8. 29 bones
    29 bones
    from so cal
  9. fordcragar
    fordcragar
    from Yakima WA.
    Very nice, thanks! Is this your photo album?
  10. chaddilac
    chaddilac
    What was the price for the f150 drums? Nice job.... might think about that on my coupe??
  11. Anderson
    Anderson
    Wow, very cool. You know, you could make some money selling finished backing plates...hint hint.
  12. hotrod8
    hotrod8
    to answer some of your questions,, there is a discription under mosr of the fotos if you inlsrge them and scroll down !!!
    is this my album ?? yes
    backing plates , ? junk yard , get everything ,so you will have e-brake parts
    drums $ ? best i remember 20$ each , the complete job was less than $200
    hub ?? hub is for outboard drum mount and it floats !!!
    i really hope this helps someone with their brake s
    oh !! i used a speedway disc kit on the front , so i still have 5 on 5 1/2 lugs all around
  13. Airborne34
    Airborne34
    from Texas
    Wow, Thanks for posting, this is just what I needed, besides 87-96 ford F-150 rear brakes are alot easier to find than decent 39-41 Ford.
